back fire
Old Oct 16, 2009 | 10:37 PM
cervantes's Avatar
cervantes
back fire
my truck backfires thru the carburetor when i press the pedal all the way to the floor,i was told that it was a intake valve
Old Oct 16, 2009 | 10:56 PM
Jermafenser's Avatar
Jermafenser
Close enough. If it backfires through the carburetor, you have timing issues.
Old Oct 16, 2009 | 11:00 PM
cervantes's Avatar
cervantes
ok ,i have a question im no mechanic,but why couldn't it be the intake valve ,and why do you say the carburetor
Old Oct 16, 2009 | 11:06 PM
Jermafenser
Because you said it's backfiring through the carburetor?
It could be an sticking/dead intake valve, but more often than not, the timing is out of adjustment.
Old Oct 16, 2009 | 11:07 PM
cervantes's Avatar
cervantes
one more thing ,when i turn the key to start the engine,it fires right up every time
Old Oct 16, 2009 | 11:10 PM
cervantes's Avatar
cervantes
if its a sticky valve ,how can you fix that,do they sell something in the auto parts store
Old Oct 16, 2009 | 11:14 PM
Jermafenser
If it's a sticky valve, you have to find the exact valve that is malfunctioning. Then you remove the head(s) and repair.
Old Oct 16, 2009 | 11:18 PM
cervantes's Avatar
cervantes
ok thank you ,im going to check the timing 1st,thanks again
Old Oct 16, 2009 | 11:36 PM
montana_highboy's Avatar
montana_highboy
Could be running too lean as well.
Old Oct 16, 2009 | 11:44 PM
cervantes's Avatar
cervantes
too lean meaning not enough gas
Old Oct 16, 2009 | 11:58 PM
montana_highboy
That's correct, i'm not saying it couldn't be a sticky valve but a lean condition can cause a "popping" throught the carb too, just something to consider.
Old Oct 17, 2009 | 12:06 AM
cervantes's Avatar
cervantes
thank you, i'm going to adjust the carb,i just want that backfiring gone
Old Oct 17, 2009 | 12:14 AM
cervantes's Avatar
cervantes
isn't there some products that will fix a sticky valve problem
Old Oct 17, 2009 | 10:26 AM
cervantes's Avatar
cervantes
okay ,i installed a vacuum gauge and it showed that my timing is good but needle was moving quite a bit back and forth ,does that mean its a valve,also how can you locate the bad valve in which cylinder,the motor misses a little,now if i have a bad valve would i still have compression on that cylinder
Old Oct 17, 2009 | 05:35 PM
4x4 Bart's Avatar
4x4 Bart
I would look at a lean carb.
fuel filter stopped up
dirt in needle valve
float level too low
jseim44
Nebraska Chapter
Apr 29, 2014 08:07 AM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
shorebird
13
Aug 7, 2009 08:55 PM
Ford_Six
Nov 9, 2002 08:56 PM
