having a bit trouble
Old Oct 16, 2009 | 09:59 AM
freightshaker69's Avatar
freightshaker69
I got a 1976 ford f250 the thing is that it just started to do this. And what it is doing is when you start it in the morning, run fine but when it get warmed i then turn it off it don't want to start up right away what could it be and sometime it will die when i come to a stop i love this truck i dont want to put it up in the garage... please help
Old Oct 16, 2009 | 11:49 AM
GLR's Avatar
GLR
Does it turn over very slowly? - possible starter. Check ground connections, battery connections etc. More info needed.
Old Oct 16, 2009 | 01:34 PM
freightshaker69
thanks GlR it turns fine i replaced the ignition coil seems to be working fine thanks again great site lot of info..
Old Oct 16, 2009 | 03:51 PM
hp246's Avatar
hp246
Check to make sure all of your vacuum lines are intact.
