Sponsored by: Auxito
frame mounts need help
Old Oct 15, 2009 | 09:27 PM
mike83f250's Avatar
mike83f250
will the frame mounts (frame stands or perches) from the 80's and 90's fit the 97 to mount a 302 motor
Old Oct 16, 2009 | 04:34 PM
steve(ill)'s Avatar
steve(ill)
well the frames are not the same so it will not be a "bolt in" deal. if you got the old mounts, thats a start, but i think you will need some modification to make the adapt.
Old Oct 16, 2009 | 05:01 PM
redwood's Avatar
redwood
The 80-96 series of trucks is a whole different beast than the 97-03 series. I believe any mixing of the two is going to require some imaginative fabrication.....
