Sponsored by: Auxito
cold weather start
Old Oct 15, 2009 | 09:09 PM
02crew's Avatar
02crew
cold weather start
i have a 2002 5.4 4wd with about 150k on it. my problem is in 40 degre or colder i have a starting problem.its intermitant but very anoying. doesnt happen all the time but seems to be when its 40 or colder so i feel i can rule out water in the fuel tank. truck will crank over just fine but it takes about 5 turns of the key at about 5 sec a crank cycle. it has always started but im sure one time it wont and i need to fix this before i get stranded somewhere. any ideas woould be great. thanks guys shawn (02crew)
Old Oct 16, 2009 | 06:59 AM
redwood's Avatar
redwood
Have you checked your fuel pressure?
Old Oct 16, 2009 | 09:23 AM
02crew's Avatar
02crew
have not checked the fuel pressure.do you think that the colder temps could effect the pressure? how do you check the pressure?
Old Oct 19, 2009 | 11:34 AM
02crew's Avatar
02crew
i should also mention that my problem also persists when the engine is already warm. anyone out there have some hints?
Old Oct 19, 2009 | 01:17 PM
redwood's Avatar
redwood
You'll need a fuel pressure tester, hook it inline, and see if the pressure is coming up when you turn the key on, and if its staying up while you're cranking it.
Has the truck thrown any codes?
Old Oct 19, 2009 | 02:41 PM
Joe Finn's Avatar
Joe Finn
Depress the gas pedal slightly when you start the truck. If it starts right up, you're IAC is going bad.
Old Oct 19, 2009 | 09:11 PM
02crew's Avatar
02crew
no codes yet. going to check fuel pressure out. what does the i.a.c control? should i clean it or just replace it? thanks guys for the help. this problem drove me nuts all last winter, forgot all about it during the summer cause she ran great but now that its getting chilly again
Old Oct 20, 2009 | 06:04 AM
Joe Finn's Avatar
Joe Finn
IAC = Idle Air Control. Some people have luck cleaning them, but I replaced mine when it went bad. They cost about $100 at the dealer. The parts house ones are cheaper, but I've heard they don't last. It's very easy to replace,
