1966 - 1977 Early Broncos
Foggy Windshield
Old 10-15-2009, 06:26 PM
Boba Fett's Avatar
Boba Fett
Boba Fett is offline
Foggy Windshield
Really hate the foggy windshield syndrome that seems to plague the early bronco...
i already put an F-150 blower and squirrel guage in my 67..... but my problem really is that the water in the heater core doesn't heat up fast enough or hot enough to defrost the windshield.....
Anyone out there put a heating element in the heater core... i know this requires soldering etc.... to rapidly heat up the water in there like they do on the fancy cars these days? Just wondering....
Old 10-18-2009, 05:23 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
If your defrost hoses are right and the heater valve opening all the way it should work fine. Did you reseal the heater box when you updated? All those little foam seals rot away and it leaks like crap.
Old 10-18-2009, 09:03 PM
Boba Fett's Avatar
Boba Fett
I did re-seal the box with new seals too.... this Bronco is a 67... and I have never taken the dash off the tub..... so I do not know if the vents that are attached to the dash are in great shape.... but I also don't have a hole in the center of the dash like the I have 74 does... so only a defroster at each side....
My defroster works, but it never gets the center of the windshield clear and really it would really help if the air was hotter.... the other thing I neglected to mention is that I have aluminuim heads... so I have a low T-stat and up graded radaitor.... in winter my temp guage barely hits the first notch.....
Old 10-18-2009, 09:11 PM
79broncodriver's Avatar
79broncodriver
79broncodriver is offline
I would most definatley consider / recommend a different / warmer thermostat for the winter... both for the sake of your defrost & engine.
Old 10-18-2009, 09:56 PM
Boba Fett's Avatar
Boba Fett
So nobody has installed/rigged up a rapid heat thing like luxury cars use that either heats the air/water like a spaceheater?
Old 10-18-2009, 10:04 PM
79broncodriver
you can rig up a air/space heater in your bronco but i dont think that will help your defrost problem. you most definatley need more heat from your engine as i think that is your biggest problem especially if your temp guage barely registers. you cant go wrong.
Old 10-18-2009, 10:19 PM
Boba Fett's Avatar
Boba Fett
Instant hot air? Why not? Anyway you look at is... if you have the oldschool setup you still have to heat all the water in the block before the air is hot enough to defrost the windshield.... if this was a Gelandawagen... as soon as I put the temp thing to hot, ws defrost and fan high and turn the car on.... I get ree-lee hot air from the vents......
Old 10-19-2009, 06:52 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Use the time tested cardboard in front of the radiator trick. Truckers use a zippered cover for adjustment. There are numerous things old VW owners have used for years as this is a common problem. But even with them a proper operating stock system will do the job. You need to get the engine temp up.
Old 10-21-2009, 08:08 AM
Boba Fett's Avatar
Boba Fett
Things do work once the truck has heated up. I am just hoping for something a little quicker if possible. What really defrosts my windshield is the engine heating up the hood and the hot air coming off it..... If you could get a 12v high temp heat tape and wrap the heater core, run it off a switch... I would probably have mission accomplished.... just wondering if anybody had done this..... I guess I am the first......
wallboyz
1999 to 2016 Super Duty
09-21-2014 08:06 AM
AbandonedBronco
1978 - 1996 Big Bronco
17
10-28-2011 08:35 PM
dcciie251
02-24-2011 04:07 PM
john72ss
1983 - 2012 Ranger & B-Series
32
11-13-2006 07:16 AM
davidoldfordfan
Aerostar
16
12-13-2003 08:48 AM
Quick Reply: Foggy Windshield
