having fuel issues please help!!
Old Oct 15, 2009 | 10:02 AM
biggums1980's Avatar
biggums1980
Question having fuel issues please help!!
So I'm trying to buy this truck from a guy i found on craigslist, its a 79 f250 2wd with the 351w and c6 auto. so i drive 70 miles to test drive this truck, it has some brake issues and some other issues. thats all fine and dandy, the cab is in excellent shape for a northern wisconsin truck. the problem is we ran it out of gas and then we absolutely could not get it running again! the guy even put a helper electronic fuel pump on the line and nothing, we tried bleeding air bubbles and i even bought a new fuel pump for it. nothing,. we even blew air into the tank to try to push the gas into the system which worked but every time we got it to run, it was only for a few minutes. then for some odd reason it took off with the help from the helper pump which we disconnected power to once we got it running. we then left it running for about 15 minutes. I then took it for one last test drive to make sure i thought it would make it the 70 miles back home and it died on my drive. what the heck is going on?? i just wanna get it home and figure out what the deal is. its a project truck that im getting for next to nothing so im not too worried about it not running, id just like to know what to watch out for. thanks!!
Old Oct 15, 2009 | 03:01 PM
Fomoko1's Avatar
Fomoko1
Welcome biggums.
The thing that comes to my mind first off is a cracked fuel pick up or a loose fuel line fitting that`s sucking air occasionally. For the real experts opinion go to the 1973 - 1979 F-100 And Larger F-Series Trucks forum: 1973 - 1979 F-100 And Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Don`t over look dropping into your local WI chapter: Wisconsin Chapter - Ford Truck Enthusiasts Forums
Old Oct 16, 2009 | 11:11 AM
1Aauto's Avatar
1Aauto
Former Vendor
welcome to FTE
trike1946
Jun 23, 2013 01:24 PM
dvw442
New Member Introductions
Oct 11, 2008 10:43 PM
pwhiteley
Jan 31, 2007 05:40 PM
Winsted Organics
Oct 10, 2006 04:44 PM
