Front end questions?
Old Oct 15, 2009 | 01:22 AM
stewart's Avatar
stewart
I have a 88 F-250 4x4 with 460. I never owned a twin I-Beam 4x4 and it seems to ride quite different from a solid axle. It seems it bounces around more than a I-beam. It has new shocks so I don't think its that. Or is there a brand or certain type of front shocks should be used?
I have a Dana 60 ford out of a 79 F-350 would it be a easy swap as bolt up and make adjustments for steering? Would I have to remove cross member?
Would this be a dumb move since I will be keeping this truck stock?
I want a more secure front end feel responses would be welcomed.
Old Oct 15, 2009 | 07:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
i don't think a 79 D-60 will bolt into your 88 due to different spring perches.
the 86-97 D-60 is a direct bolt in though
Old Oct 15, 2009 | 07:25 AM
hotrod351's Avatar
hotrod351
id check the shocks. ive had all three types of truck suspensions. i believe the twin I-beam is the heavy duty setup.
Old Oct 15, 2009 | 12:36 PM
stewart's Avatar
stewart
If one uses a dana 60 on my truck do you have to make more room where the pumpkin sits next to the cross member? The cross member looks close with the dana 50 or 53 which ever this one is.
Straight axle is the more beefy. I don't plan to use this vehicle alot with a 460 in it just a reliable sturdy/stable riding/pulling vehicle.
Old Oct 15, 2009 | 12:43 PM
rla2005's Avatar
rla2005
Check here: http://fullsizebronco.com/forum/forumdisplay.php?f=29
Although your truck is a F250 the concepts are the same.
Old Oct 15, 2009 | 03:48 PM
tjc transport
i ain't rite
take out the D-50 and throw it away.
unbolt the center drop-down brackets and throw them away too. bolt in the track bar bracket. bolt in the rear. bolt on the track bar. put the F350 steering components on. go for a ride.
it is a 1 day project for 2 guys taking it easy.
actually, if your brakes are good, you can save then from the D-50, cause everything from the hub out is the same on the D-50 and D-60
Old Oct 15, 2009 | 04:05 PM
fordmudgrappler's Avatar
fordmudgrappler
i think its the I-beam set up cause my 89 is twin I-beam and rides like a beast...my brothers is a solid front axle and rides way smoother and we both have rancho shocks. My dad's is stock and rides the best out of all of our trucks.
Old Oct 15, 2009 | 05:09 PM
stewart's Avatar
stewart
TJC Transport,
Which Dana 60 do I use another you mentioned I need a Dana 60 out of a 86 and later vehicle is this correct?
I would rather have a bolt in than do relocation of spring perch shocks,etc
Thanks
Brett
Old Oct 15, 2009 | 06:46 PM
tjc transport
i ain't rite
in 80 ford went with the ifs in the F350 4X4 till mid year 86.
so the first year D-60 that will fit in your 88 will be from an 86 F350.
the 86 to 92 are kingpins, 93 to 97 are ball joints. i prefer the kingpin rears.
when you get the rear, try to get all the parts that are associated with it. you will need to put the track bar in, because the front shackles are of an in the frame style instead of an outside the frame style like the pre 80's trucks used.
you will also need to get the F350 steering components, everything except for the pitman arm on the steering box. the geometry between the ifs steering is different than the solid axle stuff.
i have done over 10 swaps so far over the past 21 years.
very easy to do. while it can be done by yourself, but it is way easier to have a helper.
like i said before, anyone with any mechanical ability will be able to do it in one day, and that is with 2-3 beer breaks scheduled into the build.
if pushed, i can do a swap in under 4 hours if i have all the parts and my son helping me
Old Oct 15, 2009 | 08:12 PM
stewart's Avatar
stewart
Thanks Tom I appreciate the help. One other question is what is the ball park range for a 86 or later ford f-350 4x4 Dana 60 going for. Do I make a pitman arm or is there an aftermarket one available. I live in southern cali.
Thanks for the scoop
Brett
Old Oct 16, 2009 | 06:14 AM
tjc transport
i ain't rite
you use the pitman arm you have, unless you are going to go with a lift kit over 4 inches. then you will get the drop arm when you put the kit on.
i have seen D-60's priced between $200 and $1200 here on the east coast.
stoneattic
35
Oct 31, 2018 11:07 PM
1965GTFB
Jul 10, 2013 04:58 PM
Blackwaterforge
Jun 19, 2013 01:54 PM
mr.mischief
15
Jan 31, 2011 07:28 AM
dumans24
Mar 6, 2010 08:49 PM
