sloppy shifter?? did we brake something?
Is it a common problem? I've never driven a column shifted Aero, so i don't know.
But I know that a lot of people who drive automatics can get lazy when shifting, causing various problems. I know at least one person who consistently did not properly put his shifter into park, after moving to a Ford from a Chevy. It seems that the Ford shift lever required more force to move through the gears, having much stiffer action than the Chevy, whose shift lever was so easy to move that it actually bounce out of gear once when going over a rough road.
wow, I just found this thread searching for "lose shifter aerostar" in google. went and checked under the steering column and indeed the "linkage" (whatever it is called) held by two screws is very loose. Everything else I read required lowering the steering column, something I'm not willing to mess with for many reasons. Then I found this!! I have to go find the proper TORX or STAR bit to tighten the shifter mechanism 'linkage' and then I'll know if it corrects the problem, but this looks very promising. THANK YOU TO DCRB and girlfriend!
(I checked and it is a sticky).
were are these three bolts? inside or under the truck?
HA!!! my girlfriend figured it out. if it werent for her probably would have torn the steering column all apart to figure it out, since i had to wiggle a weird way to see that the bolts at the end of the shifter were both loose. she's smaller than i am, and was able to see them right off the bat. any ways it was the two bolts shown in the picture below that had wiggled loose and was making the shifter all sloppy.
hopefully this thread will help others in the future
That plate is located on the steering column under the dash.
You have to get on your back on the floor, get under the dash
on the left side of the column and with a flashlight look up
on the top of the column and you will see it. The two you
need to tighten are the Torx screws. Took care of my
problem right away. I can't remember the screw #, but
take a couple with you and you will find it.
Good luck
#29
