351 Dreaming
Old Oct 15, 2009 | 06:56 AM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by Conanski
Strictly by the numbers the I6 was rated at 260 ft/lbs at 2000rpm and the 5.8 at 300-325 ft/lbs at 2800rpm. You have to extrapolate the curve back down to 2000rpm but even if the 5.8 is down 50 ft/lbs that just puts it on par with the I6 at that engine speed and everywhere else the 5.8 owns it.
This is why the 4.9 doesn't struggle to pull things. It makes its power in the lower RPMs. That makes it a great motor for an F150 that is used as a truck.
I like my 5.0 and wouldn't change it, but sometimes its a bit lacking in the low end power department.
My previous truck was a 95 I6 automatic. I can say that pulling the same trailers and boats that it did seem to do a little better since it wasn't lugging.
Old Oct 15, 2009 | 07:16 AM
1966Tbird's Avatar
1966Tbird
the 5.0 isn't supposed to have low end and without stroking the crap out of it it probably won't have any low end they are made to rev stock they can be shifted at 6500 with no problems put a roller cam in it better heads good valve springs and some 3/8ths arp bolts in the rods and forged pistons and you can spin them as high as you want
