problem brakes
Old Oct 13, 2009 | 07:47 PM
chewford1's Avatar
chewford1
Question problem brakes
i have a 85 f250 4x4 4spd with inline 6. the problom i am having is i just put a powerbooster and master cylinder form a 92 f250 2wd and found out the the abck nut on the master cylinder is a drifferent size and cant get the flaring tool and the nut on the line. so iwas wondering if i use the line form the 92 would it cause a problem because the bends are drifferent and i real dont want to change the whole brake system right now. also was in U- pull- it yard and saw that some one put a brass nut in the same hole to block it off does this work.
Thanks for any help chewie
Old Oct 14, 2009 | 12:21 AM
Franklin2's Avatar
Franklin2
I just looked at autozone, and they have two different re-manufactured master cylinders, one for $18.00 and the other for $20.00 that will fit your truck. It's not worth the hassle to try to fit that other one on there.
Old Oct 14, 2009 | 06:04 PM
chewford1's Avatar
chewford1
thanks
thankyou again for the info
Old Oct 14, 2009 | 06:25 PM
dustybumpers's Avatar
dustybumpers
you can buy brass adapters, or re=flare the line to use the fitting from the 92. don't put a plug in it, you will be blocking off your brakes. not good. easiest solution is to do as franklin2 said.
Old Oct 14, 2009 | 06:31 PM
Terpfords's Avatar
Terpfords
Isn't that a proportioning valve on the newer model trucks? I got some PVC coated brake line at NAPA and that stuff works great, has anyone else used it. You can get those brake lines with 2 different size flare ends.
derrickmauk1003
Oct 20, 2014 10:55 PM
retrosixty6
Jun 22, 2013 12:57 PM
Mercmeister
Nebraska Chapter
Feb 22, 2013 02:25 PM
joditruck
Aug 13, 2007 06:39 AM
mwc4275
Aug 18, 2002 10:17 PM
