Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Simple but well worth changes
Old Oct 13, 2009 | 07:42 PM
51dueller's Avatar
51dueller
Have you sometimes came across something and figured if they did it another way it would make it so much better? If you've ever done an oil change on a 70's Ford pickup then you'll notice what I've done immediately. So little things have you guys done to make things better on your vehicles?
Old Oct 13, 2009 | 11:08 PM
preppypyro's Avatar
preppypyro
Well since ive never done one before Ill take a guess.
Im guessing where the oil plug is, isnt normally shaped like that, and is usually flat?
Giving that hobart of yours some use?!
Old Oct 14, 2009 | 11:11 AM
Corner Gas's Avatar
Corner Gas
I need to put a 6" extension on my oil drain so it doesn't splash all over the cross member before it hits the pan.
Old Oct 14, 2009 | 06:38 PM
93PGT's Avatar
93PGT
you mean you have to change oil in a truck?! uh oh...
haha i dont really know either? i make my dad do oil changes lol they are free that way!!
Old Oct 14, 2009 | 06:45 PM
Fomoko1's Avatar
Fomoko1
Can`t beat free......
Old Oct 14, 2009 | 07:29 PM
51dueller's Avatar
51dueller
Ford originally had the oil drain come out the side of the oil pan for some reason. When you changed oil it ran all over the engine crossmember making a mess. I relocated the drain plug to the rear of the oil pan so this will never happen again!
Old Oct 15, 2009 | 07:02 AM
96sherm's Avatar
96sherm
good idea, but it looks like all the heavy scum and dirt will still be in there after you drain it. there's a little bit of a lip where your drain plug is...
Old Oct 15, 2009 | 10:12 AM
51dueller's Avatar
51dueller
Its at the exact same height as the factory location (which goes for pretty much all the Ford v-8 steel oil pans). It can't go any closer to the edge as there is a threaded plate the plug screws into. On a brand new engine I won't have an sludge with todays oils and hopefully I won't have any dirt in it!
Old Oct 15, 2009 | 12:02 PM
preppypyro's Avatar
preppypyro
I think ya did a good job on it man, well placed too. Cleaner oil changes are nice!
Old Oct 15, 2009 | 10:36 PM
Snowking's Avatar
Snowking
Nice, another one that always bugged me is draining the radiator on 55(ish) and older Ford trucks.
Old Oct 19, 2009 | 12:10 AM
t_dickie's Avatar
t_dickie
I did the same thing to the tranny pan on my old 94 F-150. Now that saved a really big mess.
