Side view mirror
Old May 19, 2002 | 07:15 AM
jcb67's Avatar
jcb67
Side view mirror
I have a 1998 Expy 4.6, is there a way to tighten the driver side-side view mirror?(the glass). When I'm out on the highway doing about 65-70 mph and look at my mirror, it seems to shimmer(for the lack of a better term). Do anyone else have this problem?
Thanks,
John B.
Old May 19, 2002 | 10:07 AM
kwb377's Avatar
kwb377
Side view mirror
I've got a '98 also, and I had the driver's side mirror replaced under warranty about a year ago because of the same problem. Now the passenger side mirror glass is loose.
Old May 19, 2002 | 11:45 AM
jcb67's Avatar
jcb67
Side view mirror
I just had my passenger side replaced, which cost over $200.00. Firm as can be now. So I either have to replace the whole unit or just deal with the glass being loose?
Thanks
John B.
Old May 19, 2002 | 07:02 PM
RSCHAP1's Avatar
RSCHAP1
Side view mirror
Any type of coverage on these things after 3-36.I just got a 98 and it shakes like crazy...will the dealer do anything besides charge full price even though it's a common problem??
Old May 20, 2002 | 08:52 AM
kwb377's Avatar
kwb377
Side view mirror
Not sure. I've got the extended warranty, so I'll wait 'til I have it in for another repair to get the mirror fixed. I've got a list of small "concerns" I'll get fixed all at once (rear seat belt latch covers that slide down to expose the latch mech., strong odor of antifreeze after driving on the highway with no apparent leak, squeaking/rattling tensioner pulley).
Old May 20, 2002 | 05:20 PM
RSCHAP1's Avatar
RSCHAP1
Side view mirror
Do you know what is involved in fixing the mirror-dealer tell ya??It can't be as big as changing plugs is it???
Old May 20, 2002 | 05:28 PM
jcb67's Avatar
jcb67
Side view mirror
I just checked with my dealership about my loose driver side-side view mirror. The only way to fix it is to replace the whole unit. I think I'll just deal with it, as the only time it happens is when I'm on the highway....
John B.
Old May 20, 2002 | 06:37 PM
guitar4him's Avatar
guitar4him
Side view mirror
Has anyone looked into just getting a new set of the plastic pins? I replaced both mirrors with some I got from Muth mirrors and I could see how the ball-and-socket pins could get some "slop" in them, causing the looseness described here.
Old May 21, 2002 | 07:35 PM
bigmac40's Avatar
bigmac40
Side view mirror
I have a 97 Expy and it does the same thing. I don't believe it is the glass though. I put an extended mirror on it while towing my boat and that mirror was terrible. Short term fix was I put a Zip Tie around the mirror where it folds in and no more shake.
Old Sep 16, 2002 | 01:32 PM
texaskid728's Avatar
texaskid728
Post Side view mirror
I just replaced my mirrors, from Muth and noticed there wasn't a connector to plug in the heated mirror. I thought all Eddie Baurers came with heated mirrors. The new mirrors had the elements, but the vehicle did not have any place for them to plug into????
Robert
97 EB
Old Sep 16, 2002 | 07:19 PM
the4by4freek's Avatar
the4by4freek
Side view mirror
I just got a set from Meuth also.Mine weren't shaking or loose. To all of you who have replaced the glass, make sure the center pin is clipped in securely to the center of the mirror. If it isn't, it will ccause it to shake like crazy! As far as the heated mirrors.....Mine is an Eddie Bauer also it has the Signal mirrors on it. if you still have the orininal instructions, it tells you how to hook up the element. All you should need is a good ground and a switched power lead, Which if you want, you could cut in a toggle switch and turn them on whenever needed. My wifes Taurus has heated mirrors, and they are "Hot" all the time.
Old Oct 10, 2002 | 07:16 PM
expedition99's Avatar
expedition99
Side view mirror
where do i get the ball sockets from i just put signal mirrors on my xlt. and the mirror still shakes.
Old Oct 10, 2002 | 08:29 PM
the4by4freek
Side view mirror
You should be able to get the ball sockets from ford.
Old Oct 11, 2002 | 10:03 PM
expedition99
Side view mirror
thanks
Old Oct 13, 2002 | 11:53 AM
DIV16's Avatar
DIV16
If your mirror glass is loose, it might not be seated all the way on the center pivot (just push on the center of the glass to see if it is seated). Also, your friction pins or jack srews may be loose or the ball heads may be broken-off one or more of them. I had this problem and bought new pins and screws from MITO, who is a supplier to Muth, who is a supplier to Ford. Call MITO at 1-800-433-6486. The pins were $ 5.00 each. Don't let your dealer make you buy a whole new mirror!
