Re Gearing
Old Oct 13, 2009 | 01:40 PM
3KB's Avatar
3KB
Re Gearing
I have already done the math and re-gearing to 4.30 is going to put me where I want to be. 62 mph at 2000 RPM. Now the question is making sure I get the right parts. I got a quote from Bronco Graveyard for both axles $749 shipped for Yukon gears, Timken bearings and shims. Also includes the seals and what not.
The two questions,
Fair enough price?
What if any other parts should I think about while I am in there?
Thanks again,
Old Oct 13, 2009 | 02:21 PM
cartmanea's Avatar
cartmanea
I usually deal with Randy's Ring and Pinion (ringpinion.com). They are great customer service and good prices. I'd go with the Yukon gears and master rebuild kits. Are you doing the swap yourself or having a shop do it? What size tires will you be running?
Old Oct 13, 2009 | 03:01 PM
3KB's Avatar
3KB
I have 315/75R16 s (35") tires. I tried both Randy's and Bronco Graveyard. Both were knowledgeable and showed good customer service. Randy's was $300 more expensive.
I am not doing it all by myself, it is good to have buddies in the craft. It will probably cost me a dinner for him and his wife while we babysit their kids. I figure that is a good trade off. Well at least cheaper anyway.
Old Oct 13, 2009 | 03:16 PM
cartmanea's Avatar
cartmanea
Have you or your friend done gears before? Its quite a job that requires some special tools. I did mine, in December, in an unheated shop, and it was miserable. I bought Randy's Differentials book for reference and spent $300-400 on tools and some extra shims and oil baffles. Now that I've done it, I'd do it again, but it was quite a learning experience. If you don't tow heavy or often, you probably won't be pleased with the results. I really didn't notice a huge difference unloaded changing from 3.73s to 4.30s with 35s. If you don't tow often, there's other areas the money would be better spent.
Old Oct 13, 2009 | 03:27 PM
3KB's Avatar
3KB
By trade, I meant he is a Mechanic by trade. Yes he does this for a living. I am in sunny southern kalifornia and I have access to a good shop. Not too worried about freezing.
Towing is the main reason I am going to the 4.30 gears. I pull a large fifth wheel. It does fine on flat or without wind, but it works its butt off going up or into a heavy wind.
Old Oct 13, 2009 | 03:39 PM
cartmanea's Avatar
cartmanea
If he hasn't done gears before, I really recommend at least buying the Differentials book from Randy's. There are a lot of mechanics that won't touch gears. Also, replace all the axle seals while you're in there, buy oem Ford seals for the inner axle seals on the front, they are better than the ones in the kit and are pricey, so get them online. Also, spend a lot of time polishing the seal surface on the pinion to make sure there are no defects/scratches/etc. My new pinion and new seal on the rear axle have weeped since the gear swap, never dripped, but the housing looks damp, and it bothers me.
Old Oct 13, 2009 | 04:01 PM
3KB's Avatar
3KB
Thanks for the tip on the inner axle seals. I did not think of those. I will need to look up the part number and shop around.
Thanks
Old Oct 13, 2009 | 05:04 PM
cartmanea's Avatar
cartmanea
I'll see if I can find my receipt with the part number. I had to buy mine at the Stealership last minute and they were about 2X the cost of buying online at someplace like:
www.partsguyed.com
Old Oct 13, 2009 | 05:24 PM
Lubbockguy1979's Avatar
Lubbockguy1979
another parts place to look at would be fourwheel parts. some times they run specials that seem pretty cheap. if you have a factory limited slip rebuild or replace it. they wear out and the aftermarket ones are alot better. or if you want one now is the time to do it.
i would make certain you get good quality parts. with axles you really dont want to scrimp they take alot more than you imagine
Old Oct 13, 2009 | 06:12 PM
cartmanea's Avatar
cartmanea
Don't bother rebuilding the stock LS, and I wouldn't even put it back in. I installed a TruTrac when I did my gears and love it, best $560 I've ever spent.
Old Oct 13, 2009 | 09:04 PM
ptr34's Avatar
ptr34
i 2nd the truc trac. stock lsd sucks
Jmoen7
Modular V10 (6.8l)
Oct 6, 2013 06:53 PM
02X72
Mar 8, 2008 08:41 PM
Milwaukee,WI
Feb 13, 2006 04:10 PM
william_ace
Oct 28, 2003 09:44 PM
bushman
Jun 27, 2003 04:48 PM
