Truck running rough!
Old Oct 13, 2009 | 08:49 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by 460/5
mine is an FE 360 or 390, not sure which.
Pull a plug and measure the stroke 3.50"=360, 3.75"=390.
Old Oct 13, 2009 | 09:23 PM
pidaster's Avatar
pidaster
Originally Posted by montana_highboy
Is your choke opening and closing completely? a vacuum gauge will tell you if you have a valve sticking.
Choke should be good. It's got an Edelbrock 600cfm 1406 carb with electric choke. I've had to adjust the idle mixture a time or so. I guess the change between winter gas and summer gas messed it up and now they finally stopped putting ethanol in the gas at my main station.
I didn't think about the timing being the problem. It did act the same way with the old carb as well but not as bad with this one. I figured it was a carb issue and I'm not real swift on carb work.
Old Oct 13, 2009 | 09:50 PM
montana_highboy
I'm not sure how old your carb is but maybe it could use a cleaning? Berryman's B12 is great stuff, let the carb soak over night (disassembled) and blow out all the passages with an air compressor before reassembly, if the carb's new than just disregard the above advice lol.
