Carter, I've always stuck with what Ford liked to use. Check parts stores.
Summit sells Carter, may not be Chrome. Several to choose from. Depends on motor. I have found that the Holley Chrome will leak around the bolt ring. They tend to cut the diaphram. Not sure about Edelbrock.
Ray
