Seafoam???
Old Oct 12, 2009 | 06:21 PM
mlcopen69's Avatar
mlcopen69
Question Seafoam???
ok this is the first time i have used sea foam so i did what it says to do on the can as far as pouring into the carb my truck has dual exhaust and when i restarted like 5 minutes later it only smoked out of the pass. side ?? is this normal ?for as many miles as my old truck has it should have looked like it was on fire
Old Oct 12, 2009 | 07:03 PM
Jermafenser's Avatar
Jermafenser
Carburetion is not equal unlike fuel injection.
Old Oct 12, 2009 | 07:11 PM
montana_highboy's Avatar
montana_highboy
Probably the way you poured it, it all got sucked down the right bank, next time put in through your pcv or brake booster hose.
Old Oct 12, 2009 | 10:55 PM
460/5's Avatar
460/5
Zombie Survivalist
yeah. the stock intakes are dual plane. if you didnt run it back and forth between the left and right barrels, you only fed one side. i just pour it in one side to start and continually go back and forth at an easy, steady pace, then pour a whole bunch in the middle till it stalls. let it sit for 5 or 10 minutes, crank er up, and run the crap out of it.
Old Oct 13, 2009 | 12:39 AM
MT-F250's Avatar
MT-F250
Here's how to do it, it even has video.
Motor Treatment - Sea Foam
Old Oct 13, 2009 | 08:35 AM
mlcopen69's Avatar
mlcopen69
ok thanks guys ill try pouring it in to the vac systems and see how that works
Old Apr 9, 2010 | 09:32 PM
terceslil's Avatar
terceslil
Bumping an old thread to share a sale with ya'll
For those of you who use Seafoam:
Advanced Auto parts has the Seafoam Motor Treatment for Gas and Diesel Engines (16 fl. oz.) for $6.99. The sale is good till April 28, 2010.
Link
*- No Shipping Due To Restrictions
My Autozone & O'Reilly's have the same $9.99 price on Seafoam. $6.99 seems to be a better deal than the everyday $9.99 price.
If $6.99 is not cheap enough, you might want to try making your own.
Old Apr 9, 2010 | 11:11 PM
79FordBlake's Avatar
79FordBlake
Chemtool B12 seems just as good to me and its always 3 bucks a can.
Old Apr 10, 2010 | 06:03 AM
Richards73's Avatar
Richards73
yeah i like b12, has always done a good job for me
Old Apr 10, 2010 | 10:01 AM
MT-F250's Avatar
MT-F250
What ever happened to GM Top Engine Cleaner? I went into the dealer the other day to get some and they told me it's not produced anymore.
Old Apr 10, 2010 | 10:21 AM
berry1234's Avatar
berry1234
I wouldn't pour in enough to stall the truck. Maybe a possibility of hydrolocking the motor?
Old Apr 10, 2010 | 01:22 PM
terceslil's Avatar
terceslil
Usually it stalls out. Some people allow the brake booster vacuum line to suck up an entire can of Seafoam. That's when I would be worried about hydrolocking the engine. I measure out 1/4 to 1/2 of the can, and slowly pour it in. I find that is better than just sticking the vacuum line in and allowing it to suck up the entire can. I think that's when you are asking for your engine to be hydrolocked.
maverick600
Apr 27, 2014 10:35 AM
TheProfessorofTOOL
1997 - 2003 F150
Aug 1, 2012 03:48 PM
bmvtr
Oct 25, 2007 10:06 AM
condor13245
Dec 18, 2005 11:17 AM
day jefro
15
Dec 14, 2005 06:53 PM
