running boards
Old Oct 12, 2009 | 11:17 AM
jleal_21's Avatar
jleal_21
Question running boards
do ya'll think the running boards off a super duty will look good on a obs crew cab? i think i should be able to rig them on there. has anyone put some on? these are the ones i'm talking about. what do yall think?
<TABLE summary="craigslist hosted images"><TBODY><TR><TD align=middle></TD><TD align=middle></TD></TR><TR><TD align=middle></TD><TD align=middle></TD></TR></TBODY></TABLE>PostingID: 1416336924
Old Oct 12, 2009 | 09:53 PM
Oversize's Avatar
Oversize
A friend of mine did this to his crew cab gasser, they worked, not real solid though no reinforcement to control for swing inward, that and they sat a couple inches lower than they are designed to. To do it most people put them on the sheetmetal behind the rocker, that is just flat straight up and down on a obs, the superduty though that is more of a square tube and thus more rigid, less ability to flex or wing inward. so if you attach a strap to the back to prevent swing and cut down the brackets to adjust the height they should be ok.
