6.9 Temp Sensor
Old Oct 11, 2009 | 09:07 PM
algranger's Avatar
algranger
6.9 Temp Sensor
I searched around a bit but couldnt find a straight answer
My temp gauge only reads about 1/8 of the time. I'm guessing my temp sensor is bad or a have a bad connection somewhere.
Just need to know where the sensor is so i can start fiddling with it
Thanks
Old Oct 11, 2009 | 09:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Front of drivers side head.
The engine was removed so the AC compressor is not on the engine in the picture.
Old Oct 12, 2009 | 10:55 AM
algranger's Avatar
algranger
Thats just what i was lookin for, thanks man
Old Oct 12, 2009 | 12:31 PM
dakotajeep's Avatar
dakotajeep
Dave I am not sure how many times I have seen you post that picture.....super nice of you!
Old Oct 12, 2009 | 08:33 PM
Dave Sponaugle
Much easier that trying to explain, and I get to show off the engine a bit.
Old Oct 13, 2009 | 12:39 AM
bigb9582's Avatar
bigb9582
if i were to put a aftermarket temp guage in my 6.9, could i remove the engine temp light and still have a working factory temp guage??
Old Oct 13, 2009 | 06:53 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
You could but you wouldn't have the light. There is the same hole in the other head at the back with a bung in it you could use or I used one in the side of the block near the oil cooler.
Dave, why is your engine painted holden red instead of ford blue?
Old Oct 13, 2009 | 07:37 PM
Dave Sponaugle
The gauge and light are independant of each other on 6.9 era trucks.
I just wanted to be different, that is actually Ford red and silver high temp paint.
Here it is right before I installed it after the rebuild.
Old Oct 13, 2009 | 09:10 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Dave I gotta hand it to ya, that is one fantastic looking diesel Looks so cool painted Red!
Old Oct 13, 2009 | 09:20 PM
DarrinGT's Avatar
DarrinGT
What He said! Looks Great!
Old Oct 14, 2009 | 09:28 PM
bigb9582's Avatar
bigb9582
what is considered the max operating temp?? or overheating temp??
Old Oct 18, 2009 | 09:25 AM
dakotajeep's Avatar
dakotajeep
Loaded most guys say 230F is tops. The dummy light comes on ~242F if I remember correct.
Now that I have a fully functional cooling system my temps dont go over 190F unless I am loaded or going up a big hill or mountain!
Thad
Old Oct 18, 2009 | 12:04 PM
Dave Sponaugle
With the mechanical temp sensor in the head I see temps up to 235 degrees during normal operating conditions.
As soon as I am not pulling a hill, drops right back to 195 degrees.
Old Mar 2, 2010 | 06:20 AM
slimchance's Avatar
slimchance
Hey Dave. I've been searching for some answers and I think you might be my holy grail. I just bought an 87 f250 with a 6.9. The engine is not overheating, but the temp gauge is pinged at its hottest point. I know its not overheating because it does this right as the engine is started and doesnt change at all. Also, I just replaced the water pump and stat and hoses and flushed the radiator..
I replaced the sensor on the left of your infamous picture of the two sending units, and it's still doing the same thing. Do you think I have a short in the wire or is there some magical crazy thing that I am missing? This truck drives like a dream and although i am 100% positive that it isnt overheating, I am still apprehensive about going anywhere until I can get this sorted out.
I've been coming here for a while checking out little tidbits of info over the years, and the knowledge here is completely insane. I love it!
Old Mar 2, 2010 | 09:24 AM
starmilt's Avatar
starmilt
What does it do when you unplug it, is sounds like you have a grounded wire or a bad ground in the dash can cause it too.
