6.9 Temp Sensor
Old Mar 2, 2010 | 01:46 PM
slimchance's Avatar
slimchance
Originally Posted by starmilt
What does it do when you unplug it, is sounds like you have a grounded wire or a bad ground in the dash can cause it too.
Does anyone have a wiring diagram by any chance? Call it laziness, whatever. You guys have all been pretty good with the info, why not get some more?
Old Mar 2, 2010 | 10:55 PM
dyoungen's Avatar
dyoungen
Sorry, I don't have the wiring diagram but I"m sure somebody will shortly. I changed to the aftermarket gage and am wondering where, on the dash, the temp light is. I don't remember seeing it at startup.
Old Mar 3, 2010 | 10:28 AM
Dave Sponaugle's Avatar
Dave Sponaugle
83 thru 86 it was down by the wait to start light.
Not sure where it went in 87.
slimchance,
Welcome to FTE and the IDI diesel forum.
Does the temp gauge go down to the cold side when you turn the key off?
Temp gauge wire is red with a white stripe.
Look over at the passenger side near the dip stick.
You should find a connector over there where the engine harness plugs into the chassis harness.
If you can get it apart, see if the temp gauge stays on the cold side after you turn the key on with it unplugged.
Tuff48
21
Oct 10, 2015 08:08 PM
IMASAP
Jun 25, 2015 09:59 PM
castrovinci
Jun 17, 2013 09:42 PM
Lance4986
Feb 20, 2012 12:24 PM
carrfamilynj
Sep 23, 2006 09:54 AM
