2002 Explorer Plow
You have a ControlTrack Transfer case, the 5r55(x) transmission is the weak spot (if you abuse it, you will lose it) especially working at low speed behind a plow. However having said that I have the same setup on a 97, and have plowed for the past 6 winters.
Do not run it in Auto as the transfer case will be continually engaging and disengaging, make sure you come to full stop before changing directions F/R. Use the lower gears while pushing snow.
You will have to crank your torsion bars up to support the extra weight up front.
Good luck.
Good luck.
lmarkie
03-23-2017 06:56 AM
exp02
11-21-2015 12:56 AM
