Code keeps coming up
Old Oct 11, 2009 | 01:25 AM
maples01's Avatar
maples01
It's P1151, I can't figure it out, I have a fuel filter awaiting installation, have put Lucas in the fuel tank, my van runs like a raped ape, it's a 15 passenger with 3.50 gears a microtuner program on the 5.4 and it's laying rubber like never before, what gives. I can't get my tags till I can correct this, I erased the code, drove around and it's back up again. My MPG is a steady 10 city, that's hot rodding it, if I could stay out of it it'd likely go up, which would be impressive. I had to replace my DPFE last year, so I know that isn't it, o2's were done 5 years ago, I did them, previous were clean as a whistle and no codes, I just had the cash and got a deal on them.
Oh what do I do Ford guru.
Old Oct 11, 2009 | 08:11 AM
projectSHO89's Avatar
projectSHO89
Replace the bad O2 sensor....The rest of the stuff isn't relevant.
Old Oct 11, 2009 | 07:30 PM
maples01's Avatar
maples01
It's an open for translation type thing tho, the o2 sensors aren't that old.
Old Oct 12, 2009 | 07:04 AM
projectSHO89
The PCM doesn't seem to be having any problem with translation, only you do.
The age of a part isn't important. The OPERATION of the part, as detected by the PCM, is what is relevant.
Old Oct 12, 2009 | 03:56 PM
maples01's Avatar
maples01
Just the print out I got and the online description have a list of causes, no out right replace the o2 in writing on them. I'd like to know which side is bank 2 to get the right one as I'm looking down at the 2 of them from behind my engine from inside through the open doghouse of my van.
Old Oct 12, 2009 | 09:43 PM
wb6anp's Avatar
wb6anp
P1151 OBD Trouble Code
NOTICE: The information contained on this site is presented for information only. OBD-Codes.com is not responsible for any actions you take on any vehicles. If you have any doubt as to repairs on your vehicle, please contact a qualified technician.
Technical Description
Lack of HO2S-21 Switch, Sensor Indicates Lean
What does that mean?
A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Symptoms
You will likely not notice any drivability problems.
Causes
A code P1151 may mean that one or more of the following has happened:
Electrical:
* Short to VPWR in the harness or HO2S
* Water in the harness connector
* Open/shorted HO2S circuit
* Corrosion or poor mating terminals and wiring
* Damaged HO2S
* Damaged PCM
Fuel System:
* Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
* Air leaks after the MAF
* Vacuum Leaks
PCV system:
* Improperly seated engine oil dipstick
EGR System:
* Leaking gasket
* Stuck EGR valve
* Leaking diaphragm or EVR
Base Engine:
* Oil overfill
* Cam Timing
* Cylinder compression
* Exhaust leaks before or near the HO2S(s)
Possible Solutions
* See the above list of causes and go from there.
Sources: MotorCraftService.com
Old Oct 12, 2009 | 10:17 PM
maples01's Avatar
maples01
Still no answer to which side I need to replace the o2 on.
Old Oct 13, 2009 | 01:54 AM
wb6anp's Avatar
wb6anp
According to above there maybe other causes but that 02 sensor is lh forward of cat.
Old Oct 13, 2009 | 02:08 AM
maples01's Avatar
maples01
Well I'm going ahead and doing a number of things that need to be done, oil and filter change, fuel filter, clean the MAF if I can find what I did with my can of stuff, the PCV system is junk, never been a good fit before, doubt it's throwing a code now.
Old Feb 24, 2010 | 10:28 PM
Gevans17's Avatar
Gevans17
Bank 2 is Driver's side
Bank1 is side with #1 cylinder (passenger side)
Old Feb 24, 2010 | 10:33 PM
maples01's Avatar
maples01
I replaced the o2 sensor, problem was solved.
Andrew Camren
6.4L Power Stroke Diesel
Oct 9, 2016 10:37 AM
rogerranger2122
1983 - 2012 Ranger & B-Series
23
Aug 8, 2016 06:24 PM
valutechpc
Oct 29, 2015 10:15 PM
BPF250LA
May 26, 2015 07:51 AM
Torsen Rick
Aerostar
46
Sep 10, 2010 12:30 PM
