Loud noise?!?
Old Oct 11, 2009 | 12:33 AM
xluckyxbulletsx's Avatar
xluckyxbulletsx
Exclamation Loud noise?!?
There is a loud noise coming from the engine on my 06 6.0. It sounds like a blower just running very loud. When I really give it the gas I hear a squeaking sound that kinda sounds like a belt? Does anyone know what could b causing this?
Old Oct 11, 2009 | 06:39 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Could be the belt
Seriously, can you open the hood and isolate where it may be coming from? Could be a pulley or tensioner seizing up? Belt worn out and needs replacing? Any loss in performance?
Old Oct 11, 2009 | 08:28 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I would say the squeak is a belt. If it isn't continuous it is a bad spot probably on the back side of belt.
Old Oct 11, 2009 | 03:39 PM
xluckyxbulletsx
What about the LOUD blower sound?
Old Oct 11, 2009 | 03:51 PM
bismic's Avatar
bismic
The radiator fan?
Old Oct 11, 2009 | 05:29 PM
bigredtruckmi
Veteran: Navy
Originally Posted by bismic
The radiator fan?
Especially if it is very hot outside and the fan clutch has engaged to cool the beast.
Old Oct 13, 2009 | 01:04 AM
xluckyxbulletsx
I figured out it is something with the head gasket. It is blowing coolant out around the reservoir and it is over heating and smokin white smoke like crazy. THANK GOD ITS STILL UNDER WARRANTY!!!
Old Oct 14, 2009 | 07:31 PM
bigredtruckmi
Veteran: Navy
The white smoke is likely antifreeze getting into the cylinders. NOT GOOD!
Old Oct 14, 2009 | 07:47 PM
bismic's Avatar
bismic
Sounds like headgaskets AND EGR cooler (which also says Oil Cooler).
I would tow it in rather than driving it!
Old Oct 15, 2009 | 03:53 PM
xluckyxbulletsx
It was a head gasket, the oil cooler and something else. $5000.00 But all I'll have to pay is the 100.00 deductible on my warrenty!!!!
Old Oct 15, 2009 | 04:25 PM
69cj's Avatar
69cj
If you don't have one get a coolant filter and put it on as soon as you get the truck back to protect the oil and egr coolers among other things.
Old Oct 15, 2009 | 07:25 PM
Surge08's Avatar
Surge08
Prob the Oil Cooler as well, then normally replace oil cooler and EGR cooler at the same time.
Old Oct 15, 2009 | 07:48 PM
xluckyxbulletsx
Yea it was the oil cooler... Where can I get a coolant filter? and how often would I have to change something like that if I put one on my truck?
Old Oct 15, 2009 | 07:56 PM
Surge08's Avatar
Surge08
its the first I have heard of one, I'm waiting to see someone post it up
Old Oct 15, 2009 | 08:08 PM
xluckyxbulletsx
Me too I didn't know they made such a thing?!?
