1978 - 1996 Big Bronco
Bronco front wheel bearings
Old Oct 10, 2009 | 06:55 PM
bfwill's Avatar
bfwill
Have a '91 EB Bronco. What is the "Special Tool" required to get the front wheel bearings out? Winter is coming and now I have the time to work on it. Can one of these tools be made?
Old Oct 10, 2009 | 08:09 PM
helirich's Avatar
helirich
You dont need a special tool. A small screwdriver and a punch will take the lock nut off. If thats what your having the problem with. You just push the rachet teeth in and back them off as much as you can (about a 1/4 inch) with the driver, then you use the punch to back the whole nut off the same amount. After doing this about ten times, the nut will just spin off.
Old Oct 12, 2009 | 11:15 AM
alxsnmr's Avatar
alxsnmr
It is a 4 prong socket you can get at the auto parts store. Make sure you get the one for the 1/2 ton specifically the year of your truck. It is a bit pricey when compared to the regular 6/12 point sockets, but it will save you a huge headache. Makes retorquing the spindle nut more specific than guessed at. The screw driver method works but I didnt like how it cant be re torqued to the appropriate settings. Besides it mars the nuts up something terrible.
If you have the auto hubs, be sure to remove the retaining C-clip and thrust washer that is on the axle shaft. It will make removing the spindle nut(s) so much easier.
Old Oct 12, 2009 | 01:21 PM
McLeod's Avatar
McLeod
Also, if you have the 3 bolt auto hubs, the 4 prong socket won't work.
The 3 bolt autohubs use a spindle nut socket that is the shape of a large hex head.
Old Oct 12, 2009 | 02:01 PM
andym's Avatar
andym
You could do this - you could also damage the locknut or the spindle threads with this method. Not to mention it's impossible to put the correct torque on the locknut when re-assembling. Spend the $10 to get the right tool for the right job. Any parts store should have one, just ask for a Dana 44 spindle socket.
Old Oct 12, 2009 | 08:15 PM
helirich's Avatar
helirich
The spindle nut socket works on the old double nut setup. (which I changed mine to) But if he has the single rachetnut setup, it doesnt work. Before I changed mine, I removed it many times without damageing anything.
Old Oct 13, 2009 | 05:11 PM
McLeod's Avatar
McLeod
On my 93, the factory "ratchet" nuts use the same spindle nut socket as the "double" nut found on earlier models.
Old Oct 13, 2009 | 05:54 PM
andym's Avatar
andym
Not true, my socket works on both types. I originally bought the tool for my 86 Bronco, which used the double nut sandwich, but the tool also works on both my 89 and 90 trucks with the ratcheting nut.
Old Oct 13, 2009 | 07:56 PM
helirich's Avatar
helirich
Yours must be differnt than mine, I also bought the socket when I had an 88'. It wouldnt fit on my 90' untill I changed to the old design. On my rachetnut, the slots were resessed inside a steel cup. The socket drive blocks would get hung up on the cup and never reach the slots.
Old Oct 14, 2009 | 06:30 AM
bfwill's Avatar
bfwill
Thanks for all the input and help..............Off to see the wizard at Advance Auto.....
Old Oct 14, 2009 | 08:28 AM
alxsnmr's Avatar
alxsnmr
Sorry, but I assumed his 91 was like my 91 with the 5 bolt auto hubs.
66shadow
May 13, 2014 01:10 PM
SunnyBeach
Apr 23, 2014 12:37 PM
mattri
Jan 10, 2014 06:48 PM
jprix
Dec 24, 2013 10:43 AM
artieb
Escape & Escape Hybrid
Nov 4, 2013 07:43 AM
