Need To Confirm Original Colors
I am getting ready to have my 65 F100 painted and need some help to determine what the original interior and exterior colors would have been. I have attached a picture of the original Owner Indentification card that I hope lists the info. I think the vehicle code is the same info as the one on the drivers door. It is at the body shop.
When I bought the truck it was black with the interior having red:
-Steering column
-floor mats
-Door inserts
-Lower 1/2 of dash
-Door handles
-Steering wheel
Assuming that the interior was red from the factory, I have a few other questions.
1. Would the seat color match the secondary interior color(in my case-red). The seat in the truck is black and is not the original.
2. What color would the sun visors be
-Steering column
-floor mats
-Door inserts
-Lower 1/2 of dash
-Door handles
-Steering wheel
-Steering column
-floor mats
-Door inserts
-Lower 1/2 of dash
-Door handles Both the door and window crank handles are supposed to be chrome. The window crank's ***** are black.
-Steering wheel
1. Would the seat color match the secondary interior color (in my case-red). The seat in the truck is black and is not the original.
2. What color would the sun visors be White
-Steering column
-floor mats
-Door inserts
-Lower 1/2 of dash
-Steering wheel
This is how the info is listed on the Warranty Plate:
WB: 115" Wheelbase
COLOR A: Raven Black
MODEL F101: F100 2WD / 4200 lbs. Gross Vehicle Weight Rating.
BODY E81: E = Red Crush Vinyl & Red Ladder Pattern Woven Plastic // 81 = 81B Custom Cab
TRANS G: MX Cruise-O-Matic
AXLE 07: Ford 9 inch Rear Axle / 3.25-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
F10DL648709
F10 = F100 2WD
D = 352 2V
L = Michigan Truck Assembly Plant
648709 = 1965, Assembled in February 1965.
Thanks for the info. Regarding the door handles, operator error on my part. The handles are chrome and the arm rests are red.
Would the red color in the interior have been Maroon Red. Based on the color charts I can find, it seems to be the only color of red that was available in 1965
You need the Ford Salesman's Data Book to get interior colors.
The only FTE member I know that has one is camperspecial65.
The only thing I have are the factory exterior color chip charts for 1965/67.
alecs
05-28-2015 02:04 PM
mattjarma
09-22-2014 08:55 PM
jrohr
05-30-2012 08:20 AM
Big Daddy T
09-28-2010 10:45 PM
