Where do i go next?
Old Oct 26, 2009 | 11:19 PM
Old93junk's Avatar
Old93junk
Originally Posted by Conanski
If you have electrical components turning on and off when you hit a bump you probably have an ignition switch problem, change it out they don't last forever.
Yeah, it sounds like my old Ranger, go over a hard bump and most of the dash instruments, wipers and stereo go dead.........just ease the ign. key forward a little and everything comes back. The ign. switches DO wear out.
Old Oct 28, 2009 | 07:02 PM
brett12396f150's Avatar
brett12396f150
Well the only thing that cuts out on mine is the radio, most likely a wiring issue....although it doesnt lose power. Just doesnt play anything till i hit the dash.
Any other ideas?
Old Oct 28, 2009 | 07:41 PM
guyina4x4's Avatar
guyina4x4
I bought a 95 F150 6cyl 4x4 about a month ago for $300
the guy I bought it from replaced the ign module, the coil and the distributor. it ran fine for a while then went back to not starting all the time.
when I bought it, it hadn't run in 3 weeks
I used a chilton and kept thiinking these parts can't be bad. has to be something else. I scratched my head for 3 days
then a co-worker said "wouldn't be the first BAD NEW part"
with that in mind I re-did the troubleshooting and
I replaced the pickup coil in the brand new Orielly distributor and now I drive this truck every day
my point I guess is, NEW PARTS DOES NOT MEAN ANYYTHING, get the manual out and run the troubleshooting, use a meter and follow closely,it's a little confusing but it works, forget about what's new and look for what's not working.
I also found a good ignition diagnostic worksheet on therangerstation.com, made it alot easier to do
www.therangerstation.com/tech_library/images/tfi_worksheet.jpg
www.therangerstation.com/tech_library/TFI_diagnostic.html
hope this helps you
it sure helped me
exidor12
Sep 13, 2015 06:34 AM
strokerfe
17
Apr 8, 2011 09:32 PM
jrb412
Nov 5, 2010 03:15 PM
jimjoebob99
67
Nov 2, 2009 01:09 PM
Muddn351
81
Jul 31, 2004 11:04 PM
