Stop Me - Hydroboost Write Up
Old Jan 19, 2010 | 12:30 AM
  #31
bghnkinf250's Avatar
bghnkinf250
The late 70's, maybe early 80s Lincolns had Saginaw (Chevy) pumps. The reservoirs are different, but the pumps themselves appear to be the same betweern Lincoln and Chevy(except for the change to metric threads at some point.
Old Jan 19, 2010 | 12:51 AM
  #32
LCAM-01XA's Avatar
LCAM-01XA
I dunno, the Mark VII didn't come out till '84, and they all had the stupid Ford pump...
Old Jan 19, 2010 | 01:09 AM
  #33
bghnkinf250
I thought they used the Saginaw until 78 or 79.....
Old Jan 19, 2010 | 09:45 AM
  #34
LCAM-01XA's Avatar
LCAM-01XA
I had one on my '78 F-series, so you're probably right. I do tend to stick with '80s parts when it comes to cheap mods with factory parts tho, as those seem to be very easy to find about everywhere, not so much the case with the '70s vehicles. Besides a Saginaw pump will not fit the brackets made for the Ford pump, if you have a small-block engine you can use brackets from a certain E-series van, but with a diesel (like me) you're either stuck with the Ford pump, or converting to the Ford-mount Saginaw pump made by Cardone, or you have to fab a one-off setup on your own - modding the factory pump was easiest for me, altho I have to admit I'd like to hear from someone who runs the special Cardone pump...
Old Jan 19, 2010 | 12:47 PM
  #35
bghnkinf250
Could you get the bracket off a diesel van? I did not pay attention to the diesel vans, so I do not know the steering pump set up.
Old Jan 20, 2010 | 10:46 PM
  #36
LCAM-01XA's Avatar
LCAM-01XA
IIRC only the 300 and 302 vans used the Saginaw pump.
Old Jan 21, 2010 | 12:02 AM
  #37
bghnkinf250
The one I got it from had a 351w. Per RockAuto, the Diesel vans also had the Saginaw.
Old Jan 21, 2010 | 12:17 PM
  #38
LCAM-01XA's Avatar
LCAM-01XA
That's odd, which years diesel vans? I'll have to check on it next time I'm at the junkyard, but I really don't remember seeing a Saginaw pump in a diesel van...
Old Jan 21, 2010 | 08:47 PM
  #39
bghnkinf250
I just typed in one for a mid 80's econoline with a diesel and it came up.
Old Jul 29, 2010 | 06:33 PM
  #40
Timbo1985F150's Avatar
Timbo1985F150
Hi,
I am new to the board and I'm bringing a 1985 F150 back to life after sitting for 6 years. I just wanted to say what a great job you did posting your work... the pics... the write-up... this is THE way to do a forum like this. So helpful when we share info so clearly like this with our fellow enthusiasts. I hope everyone takes a cue from you.
Tim
Old Jul 31, 2010 | 05:36 PM
  #41
bghnkinf250
Thank you Tim, I appreciate the kind words, and welcome to the forum.
Old Jan 22, 2011 | 10:37 AM
  #42
giangiw's Avatar
giangiw
1986 Ford F150 4x4 brakes do not bleed
I am very new to this website and didn't know where else to start.
I experienced a leak in the front brake line and replaced the front and rear brake metal lines along with the master cylinder. I bled the MC and installed it. I can not get any fluid to come out of the rear lines at all. I can build some pressure on the brake system with the truck off but when it is running I hear a hissing and the pedal goes all the way to the floor. I believe I have a power booster system (it looks about the size of a radar detector with a red light that comes on everytime I press the brakes...the hissing seems to be coming out of it)
I am not sure if there is an obstruction in the line or not.
Anyone out there that can point me in the right direction?
Old Jan 22, 2011 | 10:38 AM
  #43
ctubutis's Avatar
ctubutis
Diesel engine?
Old Jan 22, 2011 | 10:41 AM
  #44
giangiw's Avatar
giangiw
Sorry no it is not a diesel 5.0 liter stick gas engine.
Old Jan 22, 2011 | 10:50 AM
  #45
ctubutis's Avatar
ctubutis
Radar-detector-sized thing with a red light is what made me ask about a diesel engine, the
description of that device has me flummoxed.
Pictures are helpful....
