help with doorpin
Old Oct 9, 2009 | 12:20 PM
coop26's Avatar
coop26
help with doorpin
'96 F150, reg cab.
My driver doorpin is messed up. When you open the door the interior light doesn't come on. So I figured the pushpin switch just had either gone bad with corrosion, etc. I haven't gotten around to changing the switch out, but today I had an observation...keep the keys in the ignition and open the door and the idiot buzzard goes off. So I guess the switch is working. Is there somewhere else I need to check like on the fuse box or something for a relay or something of the like to get my interior light going? It comes on when you open the pass side door.
thanks in advance!!!
Old Oct 9, 2009 | 12:54 PM
DasCheckers's Avatar
DasCheckers
Have you checked the lightbulb?
Also, check for corrosion in the socket.
Old Oct 9, 2009 | 12:58 PM
coop26's Avatar
coop26
the light works. you can get it to come on with the pass side door.
Old Oct 10, 2009 | 08:11 PM
coop26's Avatar
coop26
any other ideas?
Old Oct 10, 2009 | 08:17 PM
truckrider814's Avatar
truckrider814
$2 for the new switch in the door, replace it and see if i works mine would work sproatically untill i replaced the switch.
Kyle
Old Oct 10, 2009 | 09:51 PM
coop26's Avatar
coop26
is there a switch in the door itself? or are you talking about the switch on the doorjamb, near the kickpanel?
Old Oct 10, 2009 | 09:57 PM
truckrider814
Yeah the one in the doorjamb
Old Oct 11, 2009 | 12:21 AM
Sportruk's Avatar
Sportruk
On the drivers side pin switch, there is 3 wires. Green/Yellow is power feed, Red/Pink is to the warning chime and the Black/Light Blue is to the interior lights. Either the switch is bad or there is a problem with the Black/Light Blue.
05-X
Jan 5, 2012 07:56 AM
rhino_160
Oct 23, 2008 12:12 AM
eodmule
Feb 24, 2008 07:35 AM
Marty's 97 F-150
1997 - 2003 F150
16
Jan 21, 2008 09:29 AM
Pkowis
Jul 27, 2007 03:35 PM
