Front balljoints
Old Oct 8, 2009 | 01:58 PM
Ruby's X's Avatar
Ruby's X
Front balljoints
Are front balljoints do-able for us weekend mechanics or should I do what the chilton's manual said and let the pro's do it.
Old Oct 8, 2009 | 02:12 PM
onelionhunter's Avatar
onelionhunter
Doable
They aren't too bad, just need to rent a ball joint press from bumper to Bumper or Napa or whoever, IMHO.
Old Oct 8, 2009 | 02:16 PM
Ruby's X's Avatar
Ruby's X
So you can rent the tool? The mechanic at the shop I talked to said it took him three months to get this tool.
Old Oct 8, 2009 | 02:18 PM
onelionhunter
Rental
Last set of ball joints I did, it was $100 deposit at bumper to bumper, free rental, just have to leave the deposit until you return the tool. I personally think you may want to talk to a different mechanic, something sounds fishy with the one you have now......
Old Oct 8, 2009 | 02:25 PM
Ruby's X's Avatar
Ruby's X
That's what I thought. Thanks for the reply. Mechanic said it would be about $100 in parts and $600 labor. I'm calling bumper to bumper!
Old Oct 8, 2009 | 02:40 PM
riverrat41's Avatar
riverrat41
Ball Joint Replacement Write-Up For Ford F250 F350 Super Duty
This is a great step by step.They are right about renting the press.It would not hurt to buy some beer and invite a couple of buddies.The extra hands help alot.
Old Oct 9, 2009 | 04:21 AM
Ruby's X's Avatar
Ruby's X
Thanks for the link riverrat. Great right up! Will save me lots of money. Appreciate it.
Old Oct 9, 2009 | 07:50 AM
riverrat41's Avatar
riverrat41
Hope it helps.Did me...Good luck
Old Oct 9, 2009 | 09:55 AM
mechelement's Avatar
mechelement
He's either lying, or he owed the Snap-On guy a ton of money and the salesman refused to give him another tool until said mechanic brought down his balance.
I bought a Universal OTC ball joint press kit and the Super Duty adapter kit and received it within a few days.
Old Oct 9, 2009 | 02:03 PM
Ruby's X's Avatar
Ruby's X
Thanks again for the reply's. This mechanic was really giving me the run around. Finally got him to tally everything up and it came to $1100. Called Bumper to Bumper and they are on sale now. $250 for two upper and two lower, plus another $200 for vacuum seals and dust covers. $700 savings, priceless! I really appreciate the help guys.
Old Oct 9, 2009 | 02:10 PM
riverrat41's Avatar
riverrat41
Check your local Ford House.I bought all the seals,u-joints,and o-rings from them and they were right about the same price as your local parts chains.All Motorcraft stuff.Same part numbers as in the write up I sent you.
Old Oct 9, 2009 | 07:12 PM
megawatt00's Avatar
megawatt00
A couple of members here have used these and swear by them 4x4 upper lower ball joint kit F250 Super Duty 99 04 :eBay Motors (item 160345723627 end time Oct-28-09 12:38:54 PDT)
much cheaper in price also.
Old Oct 11, 2009 | 03:26 AM
Ruby's X's Avatar
Ruby's X
Would you happen to know if they would fit a 03 Excursion Limited 4x4 with the 7.3?
Old Oct 11, 2009 | 07:19 AM
megawatt00's Avatar
megawatt00
I believe that the EX 250 and 350 all share the same ball joints.
Old Jan 26, 2010 | 07:48 PM
sean23johnson's Avatar
sean23johnson
WOW Those are cheap!! Do you know how they are holding up???
