large valve 390
Old Oct 8, 2009 | 10:40 AM
cparks's Avatar
cparks
large valve 390
I am having the 2.09 and 1.65 valves installed in my C4AE-G heads for a 30 over 390 engine. Does anything need to be done with notching out the top edge of the cylinder for the valve? Looking to make sure the valve is not going to hit the block in the upper cylinder area.
Old Oct 8, 2009 | 06:00 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Depends on the lift of your cam. It would be a good idea to mock it up with clay and check. The exhaust side is often the culprit. Easy fix to notch them just don't get carried away.
Old Oct 9, 2009 | 12:32 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Exactly. With the overbore, it might not be necessary, but always good to check. Also, check your valve-to-piston clearance while you're doing all that work.
raven3
Nov 22, 2014 12:28 PM
beanhead6D5
Feb 26, 2012 06:25 PM
caleb1563
Jul 6, 2011 05:46 PM
banjopicker66
May 26, 2002 06:20 AM
jowilker
Jul 11, 2000 09:49 PM
