Exhaust leak fixed
Old Oct 10, 2009 | 12:53 PM
Stewart_H's Avatar
Stewart_H
Very nice.
I got to see them on the Ex today and powder coated black manifolds look nice. Almost makes me wanna do them just for the looks.
Stewart
Old Oct 10, 2009 | 01:06 PM
87 F-150 I6's Avatar
87 F-150 I6
wow, good thread! I wonder if you took a small mirror with a adjustable head and poked back behind the manifold if you could see the soot? Makes me curious?
Old Oct 10, 2009 | 02:07 PM
Terryw5782's Avatar
Terryw5782
Boy, I sure wish I had taken a better look at what you were doing prior to the actual removal of the manifolds. Did you see any evidence of leaks when you could finally look at them up close just prior to the actual removal? Or is the only visible evidence the soot on the manifold itself after removal?
Old Oct 10, 2009 | 02:59 PM
duck fan's Avatar
duck fan
Because racetruck
Terry, I could see it around the exhaust ports when I got into it. With the wheels off and the fender liners removed, the manifolds are really easy to see.
Old Oct 10, 2009 | 03:19 PM
milleroutdoors's Avatar
milleroutdoors
Originally Posted by F350-6
The reason I asked is those bolts tend to seize up pretty quick due to the thermal shock (heat cycles). In my experience, loose bolts in an exhaust manifold are pretty rare, but not machining a surface or adding a gasket after a rebuild can easily cause a leak. Wonder if that motor has been that way from day one? Something to file away in the back of the mind for future reference.
My son is driving my father's '95 obs, it too had an exhaust leak. When we removed it the back 4 bolts were loose also. Resurfaced, re-torqued and issue solved. This truck was purchased new and has less then 100k on the odometer.
Old Dec 13, 2009 | 12:43 PM
78Southwind's Avatar
78Southwind
Nice write up......I am about to tackle this job myself. Just wondering if anyone has had any success fixing the leak with just tightening the bolts/nuts back to their original torque specs?
I am also curious, is the leak caused because the exhaust manifold is warping over time or are the bolts/nuts coming loose over time? If the manifolds are warping over time what is causing it, hot tunes or are stock engines seeing the same thing?
Old Dec 13, 2009 | 01:33 PM
JockD's Avatar
JockD
Peter - could you hear one cylinder firing (kind of a knocking sound)? Several of us have a noisy #7 cylinder (rearmost on the passenger side), which is the worst one in your pictures. Maybe it is a manifold leak?
Old Dec 13, 2009 | 04:22 PM
fifthwheel01's Avatar
fifthwheel01
I dont see any air hoses(?) Did you do all this with just that little orange socket set?
Whats the the knuckle count on a job like this?
Originally Posted by weekendwarriorfsw32
Old Dec 13, 2009 | 05:30 PM
duck fan's Avatar
duck fan
Because racetruck
Short answer, yes. It was more of a ticking sound under load. The noise was non-existent at idle, but as soon as you got in the throttle, it would make itself known.
Didn't use any air tools at all. I did use a 1/2'' drive breaker bar but I didn't want to use an impact because I was afraid of breaking bolts. I figured using good old-fashioned elbow grease would give me a better "feel".
Honestly, its one of the first jobs that I haven't killed my hands on. I did smash my thumb at one point but that was about it. I was surprised at how easy it really was.
Old Dec 14, 2009 | 12:58 AM
JockD's Avatar
JockD
Our noises hang around even at idle, so I guess it isn't an exhaust leak. Thanks for the response!
Old Feb 25, 2011 | 01:00 PM
AMG-SM's Avatar
AMG-SM
Resurrecting this informative thread.
What size socket do you use for the exhaust manifold bolts?
What is the torque rating for these?
Thanks.
Old Feb 25, 2011 | 01:04 PM
Kwikkordead's Avatar
Kwikkordead
Thanks.
IIRC it's 13mm or 1/2 inch.
I'm guessing the torque will be 20foot lb.
Old Feb 25, 2011 | 01:34 PM
  #28
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Specs say 45 Ft Lb
Old Feb 25, 2011 | 02:56 PM
  #29
duck fan's Avatar
duck fan
Because racetruck
Thanks.
Al, are you thinking of taking a stab at this?
Old Feb 25, 2011 | 09:18 PM
  #30
PaulDH's Avatar
PaulDH
Gonna have to check my exhaust manifold for leaks after reading this Thread. I smell some exhaust coming through with the heater fan on. Maybe this is a source. Nice photos.
