'91 F150 - Pulled Codes
Old Oct 7, 2009 | 07:32 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Exclamation '91 F150 - Pulled Codes
I ran my code tester on my '91 300 six. This is what I got
KOEO
114 Air Charge temp higher/lower than expected
116 Engine coolant temp low (Engine not fully warmed up?)
553 Air Management 2 Failure
565 Canister Purge solenoid circuit failure
KOER
116 ECT low
172 HEGO sensor fault/lean
213 Spout circuit open
My CEL comes on after 5 miles and stays on after that. My gas mileage isn't that good (12-14 highway with 3.08s and OD) and there is NO power above 2500 RPM, the engine just totally quits pulling.
I did replace O2 about 5000 miles ago.
I don't have factory exhaust- looking for a set of cats- have been running glasspacks and its WAY too loud.
Any ideas on how to fix or whats causing these codes would be great.
Old Oct 7, 2009 | 09:19 PM
Conanski's Avatar
Conanski
Was the engine warmed up when you did this test?
The Spout code is probably the most important, if the spout plug is missing or faulty and the circuit is open the computer will not apply any advance and the motor will be way down on power. Another way to get this code is if the wrong TFI module is on the motor, should be a grey one I think not a black one.
Old Oct 8, 2009 | 02:36 PM
798hand's Avatar
798hand
What's a spout plug?
Old Oct 8, 2009 | 03:46 PM
Chevy 6.2D's Avatar
Chevy 6.2D
I think the spout is the issue- the truck doesn't have the original engine- maybe it has wrong TFI? I have the original engine, the PO gave it to me.
Old Oct 8, 2009 | 08:32 PM
DasCheckers's Avatar
DasCheckers
This is where your spout connector should be.
This is the spout connector.
This is what it looks like plugged in.
Without it plugged in your EFI cannot sense to advance your timing under load.
Old Oct 9, 2009 | 11:23 AM
Chevy 6.2D's Avatar
Chevy 6.2D
Spout is definitly plugged in, Mine is near the dizzy, I will check wires and see if my TFI is the wrong one.
Old Oct 9, 2009 | 12:37 PM
DasCheckers
Cool man! Let us know what you find!
Old Oct 9, 2009 | 03:41 PM
Chevy 6.2D's Avatar
Chevy 6.2D
The TFI on the engine is black, the original one is gray. The plug on the truck is also gray, should I swap the TFI?
emac396
Apr 7, 2015 11:13 AM
amosmoses
Jun 25, 2011 07:22 PM
mudbug3854
Nov 29, 2010 03:37 PM
EMD_DRIVER
Sep 2, 2008 05:28 PM
clark714x4
Oct 23, 2004 09:34 PM
