1958 f-100 door rot repair
i need some ideas or info on what to do about rapirig my 58 f-100 doors both doors have rusty holes pitted rust and such around the inside weatherstrip ,it must of held water over the years.. these areas look as if it would be difficult to cut out and repair what else could i do ,also some rust in the bottom corner on the inside of both doors ,as we all know there is no patch panels for these doors 57-60 so please help thanx
Short of finding solid replacement doors, replacing the rotted metal with new is the only proper repair. Bottoms of doors are not really that complex of shapes that it would be difficult to form your own patch panels. Once you learn how easy it is to form them, you won't worry about doing other patching as needed. Do you have or can you borrow basic woodworking tools such as skill saw, saber saw, belt sander, router? If so, you can make the forming bucks needed to simplify the job. Post some pix of the problem areas and I,ll help you figure out how to repair them.
There's got to be lots of good doors in a drier part of the country. Check local ad papers... there was a guy here who advertised that he made regular trips south to bring back body parts.
Or ebay, of course. This search string will find doors:
(57,58,59,60,1957,1958,1959,1960) ford (pickup,truck) door
Fixing the door would be good practice in sheet metal work, and it's a lot more convenient to work on than something the size of a cab. Google for 'door skin replace' and you may find something helpful.
RustyNtrusty
01-25-2016 06:55 PM
bigblockford_390
11-29-2010 05:10 PM
