(E!) brake
Old Oct 7, 2009 | 12:01 PM
99SevenPoint3's Avatar
99SevenPoint3
(E!) brake
im doing a dually swap on my single wheel truck and today i was looking to see if the brakes were in good condition or needed to be switched out. And while looking around i noticed clips from the inside the drum that held the ebrake cable and i need to know is there any easier way of removing the e brake cable from inside the drum? Do you have to remove all the brake asembly off and out of the way or is there a special tool that would make things easier?
Thanks!
Old Oct 7, 2009 | 12:14 PM
Fishin76's Avatar
Fishin76
I believe the only way to remove the e-brake cable from the drums is from the inside. Even on my 2004 Screw 4x4, they came off from the inside.
Old Oct 7, 2009 | 12:19 PM
99SevenPoint3
lol thats what i was was thinking i didnt feel like doing the work but if it has to be done then it has to be done...
Old Oct 7, 2009 | 11:09 PM
doube_zero's Avatar
doube_zero
ummm....is your truck an f250? if so the rearend should be able to accomodate for dually, you just might need to install longer studs and get the wheels. I think the housing and everything is the same. I'm not 100% sure but studs and wheels is all you should need.
Old Oct 8, 2009 | 01:19 AM
LCAM-01XA's Avatar
LCAM-01XA
Double_Zero, that's a negative on the F250 rear end accommodating dual wheels - dedicated pickup dually axles are 4" wider than the SRW ones, each axle tube and shaft is 2" longer than the SRW model. The only way a SRW axle will fit dually wheels is if it's going under a cab-chassis truck due to its narrower frame, but even then the spring perches will be in the wrong locations.
Old Oct 8, 2009 | 11:33 AM
doube_zero's Avatar
doube_zero
thanks for that MLSC....did not know that
Necco-2
17
Dec 2, 2019 04:06 PM
Tyler S
Oct 12, 2011 10:59 PM
paulinkansas
Jan 6, 2011 08:29 PM
MustangGT221
Jun 21, 2007 06:37 PM
IceWagon
Jun 8, 2005 08:24 AM
