Gas leaking
Old Oct 7, 2009 | 10:41 AM
bulldogcountry1's Avatar
bulldogcountry1
Gas leaking
I have a 78 F250 with dual tanks. When I fill up, gas will leak out of the filler neck if the truck isn't parked on an angle away. There even seems to be positive pressure in the tank because the gas in the neck will be higher that the top of the tank. This has to be a vent issue, right? I just thought that was for negative pressue from the pump.
Also, the ruck routinely smells lke gas on that side, even when the tanks aren't full.
Old Oct 7, 2009 | 12:25 PM
lostinfords's Avatar
lostinfords
make sure your hoses are not collapsed going to the tank
