Sponsored by: Real Truck
Do I have a transmission issue?
Old Oct 6, 2009 | 12:27 PM
dmpallette's Avatar
dmpallette
I have a 03 F-250 6.0L Diesel 4wd auto transmission, that has twice in the last week "downshifted" into a lower gear while traveling down the highway around 70mph. Once this happens I dont' feel the truck shift gears at all - higher or lower. Once I come to a stop and turn the key off and restart the truck, the issue goes away. I feel the truck shifting fine at lower speeds. The 2nd time it happened was the same scenario as the first, was on the highway traveling about 70mph.
Got it home, turned it off and back on and took off down the street and it was shifting fine.
Any ideas what might be causing my issue.
Old Oct 6, 2009 | 01:25 PM
senix's Avatar
senix
first thing I would check out would be the level of your tranny fluid. Also the condition of it. When was it last serviced?
Old Oct 6, 2009 | 02:05 PM
dmpallette's Avatar
dmpallette
fluid level is normal. I'm not sure the last time it was serviced. I got it with 84k miles, and it has 98k miles on it now.
Old Oct 6, 2009 | 10:35 PM
EXv10's Avatar
EXv10
Consult the experts at your local tranny shop.
Old Oct 7, 2009 | 12:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Does the speedo go nuts or the ABS light come on at the same time?
Old Oct 8, 2009 | 09:35 AM
dmpallette's Avatar
dmpallette
Speedo doesn't go nuts it stays steady around 3k at 65mph when the condition occurs. Haven't seen the ABS light come on either.
Old Oct 8, 2009 | 12:00 PM
krewat's Avatar
krewat
If it were me, I'd hook up a scanner and watch "road speed" when it does this. Sounds like the PCM thinks the speed is not what it really is.
Is the OD light blinking when it does this?
Old Oct 9, 2009 | 12:43 PM
dmpallette's Avatar
dmpallette
Thanks for the replies. I'll be taking it in service dealer to figure it out. I'll post the results when I get them
Old Oct 9, 2009 | 12:44 PM
dmpallette's Avatar
dmpallette
also, my OD light is very dim when it is on, so couldn't tell if it was blinking or not.
Old Oct 9, 2009 | 01:45 PM
krewat's Avatar
krewat
I wonder if the wires in shifter have broken/shorted? It's a "known issue".
