Chassis Enginering Front End?
Old Oct 6, 2009 | 09:31 AM
abrauer's Avatar
abrauer
Has anyone used or know someone that has used the bolt in mustang II front end from Chassis Engineering? Being that it is a bolt in and My welding skills are pretty much non existant do you think this would be a good option for a 52 F-1? I have someone that can weld the other types in but if I can do it myself I would prefer to. Any advise would be great.
Thanks,
Adam
Old Oct 6, 2009 | 02:41 PM
Old F1's Avatar
Old F1
This will bump you back to the top for the afternoon shift.
I have always used the weld in but I can think of no reason why not to use the bolt in. Getting to say “I did it myself” has no price.
Old Oct 6, 2009 | 03:27 PM
cmoritz's Avatar
cmoritz
While I don't have any personal experience with Chassis Engineering's bolt-in system ,..I have heard nothing bad about them.They offer alot for the $$ thru-out the line of products.Another option may be Jim Meyers Racing in Washington.Don't know if he makes a bolt-n for your bonus built, but I know it's available for the later model 53-56,and a very well built unit at that.
There is a bunch of info on this site for the Jag front-end..another option..and not very difficult either..always something for somebody around here.
Old Oct 7, 2009 | 05:12 AM
Wayne S's Avatar
Wayne S
I have the CE M11 installed on my 48 project.I have not had it on the road yet so I cannot give you any feedback there.It is really easy to install.I met a guy at a cruise-in this summer that has the CE in his F1 and he told me that installing the suspension was the best thing he has done to his truck.
Old Oct 9, 2009 | 12:01 AM
Squeak51's Avatar
Squeak51
C.e. Ifs
While I haven't bought the C.E, MII bolt in IFS yet, I plan to. I asked this very question some time ago and got a number of positive responses. Check this out:
https://www.ford-trucks.com/forums/4...ii-advice.html
You'll see responses that say the MII was built for a much lighter vehicle. They fail to note that the MII offered by C.E. and others is NOT the same as the origianl MII/pinto. Those vehicles did not use tubular upper and lower control arms among other things. Doing searches on this forum will yeild the kind of information that you need to make your decision.
Good luck,
Chris
Old Oct 11, 2009 | 07:07 PM
terryb4471's Avatar
terryb4471
1950 f1
[IMG]file:///C:/Users/HP_Owner/Pictures/000_0012.jpg[/IMG]
[IMG]file:///C:/Users/Public/Pictures/000_0011.jpg[/IMG]
I'm using the Chassis Engineering bolt on crossmember. No problems with the install. I hope the pictures show up. I have not put the truck back together so no on the road testing.
Terry
Old Oct 11, 2009 | 07:29 PM
terryb4471's Avatar
terryb4471
Sorry no pictures, I'm still trying to fiqure it out.
Old Oct 11, 2009 | 07:38 PM
councilman's Avatar
councilman
You also need to find out if it is compatible with the engine you are going to use. Mounts? Oil pan ? Etc.
Old Oct 12, 2009 | 07:22 AM
reed1951's Avatar
reed1951
I have used a chassis engineering front end and bolted it in myself. It does feel really good when you do it yourself. It looks great to me too. It seemed to strengthen the frame quite a bit too.
Old Oct 12, 2009 | 07:29 AM
reed1951's Avatar
reed1951
Here is a pic of it:
Yeah I needed to do a little garage cleaning, but i dont live there anymore so it doesnt matter lol
Old Oct 12, 2009 | 07:15 PM
terryb4471's Avatar
terryb4471
Here are the pictures of my truck. Everything went well. I used the chevy mounts. The engine is a LS2.
Old Oct 12, 2009 | 09:08 PM
Squeak51's Avatar
Squeak51
It looks like you are using the full lower control arms as opposed to the strut rods. Can you tell us what went into that decision?
Thanks,
Chris
Old Oct 14, 2009 | 05:12 PM
terryb4471's Avatar
terryb4471
That what chassis engineering recommended. The person I talked to said that the strut rod type gave more support for the lower control arm. I also went with their trans mount crossmember.
Terry
Old Oct 14, 2009 | 05:16 PM
terryb4471's Avatar
terryb4471
Sorry I read your post wrong. I'm using the strut rod type. Sorry the pictures are so small. Still trying to figure it out. I'm also having trouble uploading pictures to my photo album. I can email you a bigger picture if you want.
Terry
Old Oct 14, 2009 | 06:02 PM
Squeak51's Avatar
Squeak51
That's OK. I had thought the strut rod type lower control arm was stronger as well. In some circles, they are frowned upon mainly because they say they bind. I tend to feel that if they are installed properly, that is not a problem. Thanks for the information.
Chris
Adam from NZ
Feb 5, 2014 04:44 AM
Shawn Lewis
18
Jul 31, 2012 10:26 PM
tiger_698
Oct 9, 2008 08:04 PM
89MustangGX
20
Mar 27, 2004 09:46 AM
Josh Adams
22
Feb 22, 2003 02:08 AM
