Lots of chassis questions
Hey guys. I am new to rebuilding/restoring trucks. I’ve always wanted to do it, and decided that I’d do it with my dad because he doesn’t have many years left. He seemed pretty knowledgeable before I started. Well now that I’m starting to get the thing torn down I’m doubting he knows what he’s talking about. So I have a few questions (because I know almost nothing).
The first question would take care of pretty much all of them. I was going to just order the complete chassis from TCI, but come to find out, they don’t sell enough for the 1950 Ford F1, so they stopped making them. Are there any companies out there that still make them? I liked TCI because they made it specific, from the type of front and rear end you wanted, all the way to putting in the mounts for the engine and tranny.
If I’m not able to get a complete chassis, will the old from on the ’50 hold up to a 302 pushing 330hp? If it won’t, is there another chassis that I could use? Or is there one that would be better to use even if the chassis is good?
If I do stick with the chassis I have, I’ve already got a TCI Mustang II front end. Ill try to find someone to weld it in for me. Would leaf springs be enough in the rear with a Ford 9” rear end?
I’m sure I’ll have more questions as I get further into the project, but I figure if I can at least get the chassis started, then I’m one step closer to driving my dreams. Thanks for the help!!!
welcome to the board,
alot of folks here use the factory frame and swap in what the want, but some box in the whole frame, (i just boxed in sections) to make it stronger/stiffer.
leaf springs with a 9" rear is a good setup, been used 1000's of times... just remember all 9"s are not the same, different widths - strength - etc.........
Welcome tiger_698-
Looks like we are neighbors. There are several places you can purchase a complete chassis. Some that come to mind are Cornhusker Rod & Custom and No Limit. Locally, you could call Jason at Pete & Jakes in Peculiar, Mo. They can probably build a new chassis for you or weld in the TCI IFS you already have. If your original frame is in decent shape Pete & Jakes can set it up for you. They are good people to deal with and can do most anything your pockets can afford. Good luck.
You always get what you pay for, but I'm trying to get it restored with only $10000. the front and rear suspension and engine are gonna eat up almost all of it.
A '56 has always been my dream truck. When I was in Afghanistan my dad said he found one in decent shape for $500. So I sent him the money to get it. I got home and found it was a '50. And I would probably try to sell it to look for a '50, but my dad doesn't have much time left so I wanted to get started while I could. I'll just have to learn what I can from this one, and then get the '56 later.
BlueOvalBud
01-23-2017 06:28 PM
jeffgoll
06-12-2016 06:04 PM
boehmtrent
03-29-2015 02:10 PM
REDHTGT
03-03-2015 07:16 PM
Greywolf
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-09-2007 08:49 PM
