Vibration/Hum from 50MPH+
Old Jul 26, 2016 | 07:25 AM
CheckYosef's Avatar
CheckYosef
I have recently picked up a weird kind of vibration/hum whenever I get up to about 50mph and all the way through 80. It is there when I'm accelerating, decelerating, and cruising at a consistent speed. It sounds like it's coming from the front drivers side.
I jacked the front wheels up last night to check for play in the wheel bearings but they seemed solid. I am pretty sure my front U-joints are going out (front wheels bind up in 4x4), so I'm going to have the shop see if they can pin point where this noise is coming from. Could the U-joints be making this noise?
It seems like I picked this up soon after I got my V/B swap done, and I'm wondering if something changed to cause it after the swap. Do you guys have any ideas what this could be?
Thanks in advance
Old Jul 26, 2016 | 10:24 AM
Gene Horr's Avatar
Gene Horr
That's the exact noise u-joints make. But so do bearings, gears, ...
But get that u-joint repaired ASAP. It is a cheap and easy repair and failure can be not only far more expensive but also a safety issue.
Old Jul 27, 2016 | 10:33 AM
sessland's Avatar
sessland
The front u-joint on my driveshaft was bad and growled at that speed.
It was also the cause of all my vibrations
Old Jul 27, 2016 | 09:50 PM
Worldwatcher's Avatar
Worldwatcher
Just had the same thing, my drivers side hub bearing went bad!
kidzstang
1997 - 2003 F150
Oct 23, 2016 11:23 PM
blanes
Mar 27, 2016 06:26 AM
pmasley
Nov 10, 2010 09:42 PM
dfboothe
Sep 20, 2010 09:28 PM
mytruckisjunk
Dec 9, 2009 11:37 PM
