service engine light comes on
Old Oct 5, 2009 | 09:58 PM
dwhite815's Avatar
dwhite815
I am unable to relocate the thread thast explains how to test the 9 pin connectors on the valve covers. My service engine soon light comes on in a pull,but goes off soon and the truck runs fine. Anything I need to worry about untill it gets worse? I hate to pull the valve covers yet as this engine does not leak anywhere with 90,000 miles on it. 1999 ford 350 a/t 4x4 all stock my fist diesel. Thanks Denny Belen,NM 87002
Old Oct 5, 2009 | 10:33 PM
Meeks's Avatar
Meeks
What the reasoning for testing the connector? Just wondering cause my truck does the check engine light thing when i'm pulling
Old Oct 5, 2009 | 10:52 PM
rbaker6336's Avatar
rbaker6336
if you have a chip or programmer it could be insuficiant high pressure oil which is normal,but you would have to check the codes to be sure.My truck does the same in a long hard pull
Old Oct 5, 2009 | 11:03 PM
Meeks's Avatar
Meeks
thanks, I do have a programmer on mine.
Old Oct 6, 2009 | 03:41 AM
Visseroth's Avatar
Visseroth
My SES light comes on when I'm pulling a heavy load or accelerating to fast down the hwy. The only thing I can figure is that it's the HPOP that's having a hard time keeping up with my demands and since I have a E99 with a 15* HPOP that would make a ton of sense and when I let off the throttle and set my cruising speed the SES light shuts off again.
belen1705
Nov 16, 2012 10:22 PM
belen1705
Oct 14, 2012 05:47 PM
belen1705
Oct 10, 2012 09:24 PM
belen1705
Oct 5, 2012 11:17 AM
