I have a 400 with a2150 just put a rebuild kit in it and now when you push the accelerator pump down it squirts gas out the little hole on the pump cover any ideas?
Did you pull the orange rubber nipple all the way in while pre-lubing the nipple with some spit or vaseline? You should see the cap on the housing almost all the way in, and a ring in the float area. Gently tug on the nipple inside.
