Hybrid Idle
Old Oct 5, 2009 | 12:58 PM
Izzy351's Avatar
Izzy351
Hybrid Idle
Anyone want to compare notes?? Here's what mine currently sounds like:
Shtuff :: SNC00103.flv video by Izzy351 - Photobucket
Old Oct 5, 2009 | 01:48 PM
stroken's Avatar
stroken
i have had the same injectors and 3 different people tunning my truck.
That my friends is tuning related.
what setting was that and what injectors are you running? cc and nozzles
Old Oct 5, 2009 | 02:23 PM
Izzy351's Avatar
Izzy351
They're Casserly 235cc/100% over nozzles. That was Tony Wildman's Daily Tune. I met with him at the PowerStroke Rally over the weekend and we'll get it worked out...
Old Oct 5, 2009 | 02:27 PM
PwerStroke99's Avatar
PwerStroke99
u also might have air in the system still, take it out and run it for several miles and see if that helps.
Old Oct 5, 2009 | 02:32 PM
Izzy351's Avatar
Izzy351
I've got 250 or so miles on it now. I would hope the air is worked out...
Old Oct 5, 2009 | 02:45 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
does it hurt the injectors to have them idle like this?
Old Oct 5, 2009 | 05:35 PM
stroken's Avatar
stroken
thes def a tuning problem. i have casserly 300/200 and my truck sounds bone stock in all my tunes but race and pull settings, and even then it doesnt romp that bad.
Old Oct 5, 2009 | 05:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Imagine what that's doing to your rods.
Old Oct 5, 2009 | 05:50 PM
stroken's Avatar
stroken
exactly
Old Oct 5, 2009 | 07:19 PM
my79f's Avatar
my79f
Hey joe sorry i dont have any input on this. I was wondering if you are going to Crandall this weekend?
Old Oct 5, 2009 | 07:36 PM
big poppa's Avatar
big poppa
I'll be taking this path in the future, subscribing..
Old Oct 5, 2009 | 07:48 PM
Izzy351's Avatar
Izzy351
I'll tell you all what -- I got home, backed in the garage and found oil EVERYWHERE. I about had a heart attack. But it seems to be coming from up top somewhere. There's oil in the valley, but none on the HPOP lines or connections. None on the turbo or pedestal, but PLENTY under my truck that ran down the back of the block. I thought it might be coming from the VCs, but the side of the block is dry, and I doubt it could get from the VCs to the valley -- does that make sense? It's just odd that everything has been fine for 300 miles, and suddenly I have an entire bottom side covered in oil...
EDIT: No, I'm not going to Crandall this weekend. Sounds like fun though...
Old Oct 5, 2009 | 08:05 PM
Orezona's Avatar
Orezona
Kris, help the OP or us out...What is it doing to his rods?
You and Stroken should know for sure. What are you two up to? Four, five, engines between the two of you?
Old Oct 5, 2009 | 08:49 PM
F350-6's Avatar
F350-6
Originally Posted by stroken
exactly
So how many visits with the tuner does it typically take to get things settled down? Joe hasn't got any updated tunes yet for the new injectors.
I guess I took a nap, what's going on in Crandall?
You know the drill. Clean it up and narrow things down. Front middle or back of the valley? How low is the oil on the dipstick? Did you inspect the valley for signs of oil after you got the valve covers bolted back on after the swap?
Ouch.
Old Oct 5, 2009 | 09:18 PM
Tenn01PSD350's Avatar
Tenn01PSD350
What do you live in an alley Joe?
That is how my truck sounded with Swamps tunes. They may have improved since then but could not fix mine. Maybe we need big oil for their tunes but mine is a lot better now after live tuning without big oil and different tuner.
Good luck with the leak and I hope it is something simple and cheap.
