Fuel Leak
Old Oct 5, 2009 | 08:13 AM
koski19's Avatar
koski19
Fuel Leak
After 228,000 miles on 99 F250 PSD sprung a fuel leak yesterday. Cold in the morning, took truck out to the store and when I returned had a fuel spot on driveway. Also had smell of fuel in cab. The fuel ran down the back of engine over the trans inspection cover plate and hit the ground.
I'm going to check today and try to locate this leak. Anyone want to give me some guidance here. I'm thinking "O" ring for fuel rail? Thanks Jeff
Old Oct 5, 2009 | 08:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Jeff, look around your fuel bowl. Check the lid for leaks, I had a leak at the lid a few weeks back. Most of the time a fuel leak is at the drain valve. click here You might need to clean the top of the engine, then run the truck to find the leak. Good luck.
Old Oct 5, 2009 | 08:37 AM
WA.Ranger's Avatar
WA.Ranger
I agree with Rick.
Old Oct 5, 2009 | 08:39 AM
koski19's Avatar
koski19
Thanks for your input. I'll be checking it out when the sun comes up.
I'll post what I find. Jeff
Old Oct 5, 2009 | 01:47 PM
koski19's Avatar
koski19
The fuel bowl drain valve is leaking. I ordered the "O" rings..
Thanks for the help.....Jeff
JefflovesF250s
Nov 11, 2014 10:24 PM
jeffk813
New Member Introductions
Oct 24, 2013 09:58 PM
jgrzebin
Nov 28, 2011 10:34 AM
Jeff3298
May 3, 2008 04:59 PM
supercab78
Mar 23, 2002 05:52 PM
