"Brake Switch ?" HELP!!!!!
Old Oct 14, 2002 | 11:14 AM
Dirtyboy's Avatar
Dirtyboy
I own a 97 expy and it's stuck in park and has no brake lights. The dealership told me it's the brake switch but want to charge me 200 to replace it. How hard is this to replace on my own and where is it located? Any help yall can provide will be greatly appreciated ..
Old Oct 14, 2002 | 04:55 PM
the4by4freek's Avatar
the4by4freek
If you look under the dash board right where the brake pedal is connected to the pivot point, you will see the brake switch. It has a couple of wires on it. It also has a spring inside that you should be able to see. Before you change it check all your fuses. If one is blown and the lights are not working the transmission will not reckognize the brake pedal interlock feature. Therefore it will not shift from park. These damn things run everything from a computer or 12 volt switches and relays! Even the 4x4 is electronic!
Old Oct 14, 2002 | 11:25 PM
97 awd xlt blue's Avatar
97 awd xlt blue
01 sport trac 4x4 black
97 explorer xlt AWD v8 blue
91 f-250 xlt lariat 4x4 blue/gray
84 ranger xlt 4x4 black
94 explorer xlt 4x4 purple/gray
96 explorer limited 4x4 gree
had same prob in my 98 expy 4x4 it was a relay but i had to change all of om to find the burned one after that it worked fine. p.s. i hope it dident happen in a bad spot mine did it in mcdonales drivethur it really sucked
Old Oct 16, 2002 | 08:03 PM
Dirtyboy's Avatar
Dirtyboy
Hey I really appreciate the help yall ..in the drive through man o man I know that wasn't fun at all... :0 Thanks again.
Old Oct 17, 2002 | 12:26 AM
97 awd xlt blue
96 explorer limited 4x4 green
got that right!!!!!!!!
put it in park to get all the food and went to leave and would not go in to any gear i was lookin at all the fuses and all the peopl where honking and fliping me off it wasent fun i just hope urs did it in ur drive way or some place like that...
did u get it fixed?????
Old Oct 19, 2002 | 11:39 PM
1999XLT's Avatar
1999XLT
Old Oct 23, 2002 | 12:54 PM
Dirtyboy's Avatar
Dirtyboy
No mine did it one night after class I sat there for about an hour just getting hot cussing at the truck..it was a funny sight....nah havn't had a chance to get in there yet hopefully will get it dont this saturday.
PJPVI
Jan 13, 2014 06:44 AM
fetusgrinder
Sep 24, 2010 01:04 PM
Defcon888
Electrical Systems/Wiring
Jan 17, 2007 07:20 PM
quent
Sep 6, 2004 08:21 PM
quent
Sep 6, 2004 08:11 PM
