Power Door Locks
Old Oct 4, 2009 | 09:31 PM
jeff9942's Avatar
jeff9942
Power Door Locks
I am sure this has been covered somewhere so if someone could point me to it that would be great...as not to waste anybody's time
I can lock/unlock with power switch I can unlock/lock doors with key however I can not unlock the door with the key if I used the switch to lock it. I use the key I can unlock it with the key , if I physically push down lock I can open with key I hope this made since.
94 F150 XLT 351W
Old Oct 4, 2009 | 11:08 PM
Hunt4Fun's Avatar
Hunt4Fun
Welcome to FTE! Sounds like the door actuator is seizing up or the rod from the actuator to the locking mechanism is bent.
Either way, there is not much you can tell until the interior door panel is off. Then with a good, bright light you'll be able to see what is going on. Be sure to put the water seal back on securely.
toddrochester
28
Jan 20, 2012 06:33 PM
kev100
Feb 18, 2011 07:30 PM
jjs2032
Apr 22, 2008 08:27 AM
jonboy88
20
Jun 12, 2006 03:35 PM
