Bronco II Ford Bronco II
84 bronco 2 transmission problem
Old Oct 4, 2009 | 09:09 PM
armadillodrunk's Avatar
armadillodrunk
I have a 84 ford bronco 2 5 speed transmission that came out of a truck i wrecked it will not go into 1st or 2nd gear it goes into all other gears just fine the reason i am reusing this transmission is because the other transmission that came out of a 87 has a different sized shaft and length so it will not work with anything i currently have it bolts up to a 2.8 that has been bored .30 over and has about 10,000 miles on the engine so it makes sense to reuse the engine however if i cannot get this transmission to work i may be forced to try and make the 87 trans work on it although i would prefer to get the 84 one to work as it seems to be better built any help any one could give would be greatly appreciated
Old Oct 5, 2009 | 02:25 AM
rebocardo's Avatar
rebocardo
I would look at the shifter not being installed properly, especially if the shifter was removed while in gear.
If you have a FM-145/146 if there are any broken parts it would be easy enough to check for bits by removing the lower cover.
Old Oct 5, 2009 | 08:15 PM
armadillodrunk
I checked the shifter and it is installed correctly however i have not yet had time to take the bottom plate off to have a look at it yet to see if any thing is broken i will do that tomorrow and get back to you on that thank you for your help
broncoman87
Bronco II
Mar 28, 2015 07:55 AM
mwood553
Bronco II
Mar 10, 2015 04:43 PM
MRBf3504X4
1978 - 1996 Big Bronco
Aug 26, 2014 11:08 PM
300Jim
Dec 6, 2013 01:48 AM
