You would think from the auction title, right? Well I asked the seller to be sure and they replied: Fits styleside only. Then I asked another question and they reply saying flareside only?? So my third question was to try and get a clear answer out of them and they never replied again?? So THAT is why I'm asking here. You guys are the experts!
Heh, I was just giving you a hard time. "Styleside" and "Flareside" and "Stepside" are just ways of referring to the same thing: a narrow bed.
Go outside and look at your taillights. Do they look like that shape? I know the F150 in certain applications had the same taillights as the Super Duty. IIRC, there's not much change between the years.
Specifically I'd really like to know what effect, if any, it has on your blinker. On my TJ Wrangler if I convert to LED tail lights or blinkers it will blink really fast as though there were a bulb out because it's not being put under the same load as with a set of incandescents. I'm curious as to what happens on the Super Duty, especially since I'm planning to add the Ranch Hand rear bumper with the LED reverse lights, and this would help tie it together nicely.
By the way...any reason these wouldn't fit an '07 F250? Seems like they'd be the same...
they will fit an '07, since the tail lights are the same from 99-07 for the superduty.
Not quite. Styleside refers to a "normal" bed and flareside and stepside are the narrow bed.
To the best of my knowledge the f250 and f350 never came in flareside, so it would be safe to say if they state they fit an f250/350 then they should fit.
