1978 - 1996 Big Bronco
Clear 33's
Old Oct 11, 2009 | 07:20 PM
MUSKY1011's Avatar
MUSKY1011
keep cutting the fenders till they fit
Old Oct 24, 2009 | 10:25 PM
Capone's Avatar
Capone
I would agree with Greystreak.
Using the heavy duty rear lefs creates lift because the spring doesn't yield as much as the regular bronco units. It will create a rouch ride that may affect overall ride quality.
I for one, favour a ride that parallels the stock ride.
I do like the idea of 33+ tires on it though.
Old Oct 25, 2009 | 09:35 AM
Bluebronco85's Avatar
Bluebronco85
Originally Posted by kenpobuck
This forum is a place people come to for advise and knowledge on Ford trucks not just what one person deems to be the right way.
Amen to that. I'm gald someone else believes your entitled to your own opinion. I have 33's on my 85 bronco and used the 2" coil spacers in the front and added a 1" block in the back. has just a slight rake to it now. But remember as someone else mentioned earlier your messing with the geometry and this causes alignment and wandering problems that are already a problem to start with on the ttb. I'm converting my 85 over to a straight axle dana 44 this winter from a 78 bronco to cure this problem.
Old Oct 26, 2009 | 02:28 PM
greystreak92's Avatar
greystreak92
Originally Posted by greystreak92
...I would rather spend more to do it better the first time than have to go back a fix what breaks because the method used tore something else up. Just my approach to it ladies and gentlemen. To each his/her own.
Perhaps the gentlemen who seem to think I am trying to dictate how someone should do something could read the ENTIRE post before losing their cool.
Old Jan 1, 2010 | 08:33 PM
floridamudder88's Avatar
floridamudder88
I have a 1988 bronco and I was clearing 33's no problem, there's a bump stop screw right on the inside of the brake setup(inner tire side). All I did was back the little screw out a couple turns so the tires didn't rub on the radius arm. Granted you'll have less turning radius, but I'd rather it that then rubbing the tires...
Old Jan 1, 2010 | 11:29 PM
deadeyedevon's Avatar
deadeyedevon
im all up for a shadetree/junkyard mods but on the suspension..i would stay with whats made for it, i see what greystreak is sayin. in my opinion its like doing a JY mod to your brakes, kinda risky.
Old Jan 2, 2010 | 08:02 AM
NavyMIDN08's Avatar
NavyMIDN08
what is your goal in fitting 33's? the reason can really affect the method. are you looking at going mud bogging and you need to keep your radiator out of the muck? are you going rock crawling? just bouncing along old logging trails in your local forest? just want to find your truck easier leaving the grocery store? everyone here has some valid points. if you're looking to go rock crawling, or cross any serious ditches or creeks, then you'll hurt yourself using the heavy duty springs. their lack of articulation will cost you traction when you need it most. in that case, you'd be better off to trim your fenders. the 33's on mine don't have any serious rubbing issues with fenders trimmed. plus, the lower COG will keep you from rolling as easily. hitting the deep mud holes? then you're ride quality won't matter as much. go with the heavier springs, its cheap, and while it'll cost you in steering geometry, anyone who does much mudding replaces suspension components regularly anyways. just want a tall truck? consider spacers. you'll maintain your ride height without sacrificing the softer OE springs. want a good all around rig? start saving up for a fully equipped lift kit with new springs, brackets, radius arms, etc. or better yet, but the necessary components and get busy fabricating your own brackets and radius arms. everyone here has the right answer, it just depends on the application. now play nice boys...
Old Jan 2, 2010 | 03:04 PM
deadeyedevon
yup thats the truth, it all depends
stangnutlx
Nov 19, 2014 03:13 PM
caleballen95
Jul 21, 2014 04:29 AM
guitarist41991
24
Nov 15, 2011 07:02 AM
muscletruck7379
May 5, 2011 02:04 PM
jeffzoot
Sep 1, 2007 01:52 AM
