Yep, adjust the box. When I had a new box put in a previous rig the "new reman" from GM had too much play. Techs at the dealer wouldn't adjust. Said they could try another one. Took it to a good front end shop and in 10 min it was as good as new.
I also bought a red head steering gear and am 100% satisfied.. I have zero play in the wheel.I too replaced everything in the front end and still had slop.. Then put the red head in and Presto -fixed!!
I will try adjusting it, but I may just end up going with the red head.
I am trying to decide between that and a 5 star tune, I don't have cash for both.
How much did it cost and what was the turn around time on the red head ?
Fix the steering, tuning can wait. You may get there a little slower without the tune, but you may not get there at all with steering like that while towing that much weight...
You should have seen it before the bushings, steering gear, ball joints, tie rods and bearings! it was easily 2x that bad, and I did not feel safe driving it.
The motor craft is still under warranty, I need to get a red head and return the new one i put in it.
Get a Redhead. Took a cue from Monster here and called them up myself. Talked to the owner Harvey Foster. That guy said he had rebuilt over 43,000 gearboxes so you bet I trust him. Excellent customer service, friendly people, family owned business, I couldn't be happier. Now I just need to get the damned thing installed.
I am also going to 4 Wheel Parts tomorrow to get a Skyjacker Dual Steering Stabilizer set up. Mine does not have even an OEM stabilizer, and you can feel the bumps and jerks pretty bad in steering on rough roads. My suspension is also pretty tight.
