2003 E350 Chateau - Smoother Ride
Some info: 90% of the time it is just the family with some bikes in the back, 20% of the time we are towing a 24' trailer at 6000lbs with a weight distributed hitch and sway control. The van also has a sliding door.
I thought a set of Yokohama Geolander AT-S 265/75/16 Load Range D (3000lbs) would help a little. The stock tires being 245/75/16 Load Range E (3045lbs). The 245s need 80psi and the 265s need 65psi that I could take down to 55psi with out the trailer.
My local shop suggests:
2" lift with new coils in front and blocks in the back, to fit the tires and clear the sliding door
Rancho adjustable shocks
Remove the overload leaf on the rear springs and install air bags
It would run about $2200 with out the tires.
So....Does anyone see any issues with this?? Handling? Towing? Brakes?
I know it won't ride like a Cadillac but I need to keep my kids teeth from rattling out.
Thanks for your input,
Steven
1. Changing springs in the rear to E150 spec
2. Adding air bags/springs to rear to add load capacity as needed
My reasoning behind this is; I have an e350 28' Metrotrans shuttle bus. They used an E350 because they outfitted it with a third rear axle which is setup just like commercial buses, it has a single wheel and is full air suspension. With this setup the ride when there is no load or only a partial load is actually quite smooth. To accommodate 25 passengers plus baggage I simply press a button to activate the compressed air to handle the extra load. This thing glides down the highway far smoother than I could have imagined.
The company I work for has shuttle buses running around campus all day and I've noticed they ride super stiff like there is no suspension at all. I've ridden them many times over the years to attend meetings in other buildings and when they hit a bump, it's super stiff. They are much smaller than my bus and are built on E450 chassis. I bought the shuttle for family road trips.
Instead, along the lines of Ehbrah's idea:
-I took my 2006 E350 w stock Michelin's 225/75 r16's
Switched to Michelin 245/75 R16's (after trying tires from remington that were horrible! They rode stiffer around town, and dangerously swayed more on the freeway at speeds, and they were E-rated tires!)
I have a buddy that has d-rated 265-70-16's goodyears, and he says it rides great, but I wanted to stick with e-rated for the sway at speed reason.
Michelins are worth the money!!
I knew a 265/75-r16 would fit, but the E350 vans I have seen looked as if the tires were too tight in the front.
-I had a company Deaver Springs (local shop in anaheim, ca known for building custom leaf springs), take my stock e350 leaf springs out de-arch them 1 1/2". Now my van sits near level, still has the e350 springs, rides softer, and still has close to the load capacity of an e350. My van rides noticeably less bouncy and feels more active and supple. It feels like if i were to tow, it may require airshocks to assist.
The optical illusion is now that the van is near level, it almost looks as if it was lifted.
I am very pleased with the improved ride quality and results.
