high pitched noise
Old Oct 1, 2009 | 06:36 PM
geoczir's Avatar
geoczir
Angry high pitched noise
I have an '07 F-350 6.0 L Power Stroke King Ranch with 60K miles and I pull a 16,000lb fifth wheel. I bought the vehicle used at 49K miles. Periodically when pulling up hill at between 3000-3200rpm at 55mph a high pitch noise progressively increases. (Sounds like a kettle whistle). Power is good, turbo is in range, all gauges are good. Sound goes away instantly when I let off the throttle. This also appeared once in Tow-Haul going down hill in cruise and engine accelerated rapidly above 3000rpm. The sound does not always happen. Two independent Ford diesel mechanics have no idea. The truck just went through 60K checkup with flying colors.
Any ideas?
Flumoxed.
Old Oct 1, 2009 | 06:43 PM
eddiedebb's Avatar
eddiedebb
Sounds like it might be the fan kicking in.
Old Oct 1, 2009 | 06:46 PM
dcaddi2's Avatar
dcaddi2
That would be my guess too.....
Old Oct 1, 2009 | 06:49 PM
geoczir's Avatar
geoczir
Fan kicking in makes a deep roar. This happens after fan kicks in. Doesn't happen all the time. Is there a Turbo waste gate?
Old Oct 1, 2009 | 06:54 PM
eddiedebb's Avatar
eddiedebb
There is no waste gate on the VG turbo. Maybe some one will pipe in and have an ideal.
Old Oct 1, 2009 | 07:09 PM
jboczar's Avatar
jboczar
The sound you are hearing is probably pressure venting out of the cap of the reservoir. Problem could be as simple as a bad cap venting out at the wrong pressure and as bad as headgaskets. Get it in to the dealership before the warranty is gone and have the diesel tech followed the Ford tsb related to coolant loss,cap venting,etc.
Old Oct 1, 2009 | 07:12 PM
69cj's Avatar
69cj
See if you have the updated degas cap. This has solved a number of cooling problems. About 15 bucks. Worth a try.
Old Oct 1, 2009 | 07:13 PM
eddiedebb's Avatar
eddiedebb
Are there any signs of puking around the reservoir, white looking stuff anound the cap.
Old Oct 1, 2009 | 09:23 PM
f250meangreen's Avatar
f250meangreen
I have the same problem. Unfortunately I am now out of warranty. Ford could not find where the noise was coming from and now it is on my dime. I had the noise but not puking. I guess the cap got worse and fluid started coming out. I replaced the cap and it got better but not gone. I guess I will have to bite the bullet and take it in. Hoping it is not the head gaskets.
Old Oct 1, 2009 | 09:36 PM
eddiedebb's Avatar
eddiedebb
Some dealerships will honor the warranty a pervious complaint when it is the same problem that has not been resovled. Try it .
Old Oct 1, 2009 | 09:50 PM
Benchwrench's Avatar
Benchwrench
here's my 2c
sometimes when the up pipes develop a fracture in the stainless steel 'flex' connection they will emit a high pitch whistle and of course the radiator cap will that too but it's real weak sounding and not tied to the throttle per se, besides it'll be a pukin'.
Now on the other hand, I've heard of guys who had a crack in the intercooler boot do the same thing so you might want to check that out too. A small mirror and a flashlight are helpful to see behind it.
Old Oct 2, 2009 | 06:03 AM
glsurratt's Avatar
glsurratt
Go read these two threads:
Whistle under heavy load
Wierd cycling sound when towing
Print them out. Take them to your dealer. When he figures out the problem, come back and let the rest of us know since none of our Ford dealers are smart enough to figure it out either.
Old Oct 3, 2009 | 01:59 PM
geoczir's Avatar
geoczir
No sign of puking. Ford dealer gave clean bill of health just after 60K check. He should've noticed if the headgasket was bad....right?
Old Oct 3, 2009 | 02:15 PM
geoczir's Avatar
geoczir
Glsuratt,
Read your two links. Sounds like the same thing I have. No reduction in power though and lots of peddle on the hills pulling 15-16K fifth wheel. I'll work with my Ford guy, but they're scratching their heads.
Old Oct 3, 2009 | 02:50 PM
glsurratt's Avatar
glsurratt
Originally Posted by geoczir
Glsuratt,
So is everyone else. It's not the fan clutch - they replaced mine with no change. One guy said he put on a Goodyear Gator or Gatorback fanbelt and solved the problem.
I may have an alternator or regulator problem with my truck right now and if they have to replace the alternator, I intend to have them replace the belt with the Goodyear belt at the same time. Unfortunately, I probably won't be towing in the mountains until next spring or summer, so I won't know if it fixes it or not. Mine only has the problem in temps over 85 degrees and pulling long grades with the 19K trailer.
wharthog
18
Nov 19, 2019 09:06 PM
cangim
13
Oct 9, 2016 09:59 AM
dochall
6.4L Power Stroke Diesel
Feb 16, 2016 10:06 AM
dochall
New Member Introductions
Feb 15, 2016 01:27 PM
grullman
Oct 8, 2012 07:18 PM
